emergency lights stopped working.., after about 5 flashes.. ?? |
SECHSER |
Nov 4 2009, 08:39 PM
Member Group: Members Posts: 73 Joined: 5-March 06 From: smell A Member No.: 5,669 Region Association: Southern California |
k, so i have a feeling this might not be that big of a deal.. after all i thought it was just gonna be a bad flasher relay, but then i discovered that it worked again after i disconnected and reconnected the battery. well, for 5 more flashes.. so this is just totally weird.. (IMG:style_emoticons/default/dry.gif)
anyone's got this kinda issue? could this still be a bad flasher relay? thanks in advance. |
underthetire |
Nov 4 2009, 09:10 PM
I had an old Datsun pickup that did that. It was the flasher relay on it. Replaced it and it burnt out agin. apparently on that truck if the hazzards were on and you pressed the brake pedal, things went very wrong.
detoxcowboy |
Nov 4 2009, 09:32 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I would start with a new relay, sound as electrically it is dis functional after a few clicks, it is by the way the most active hard use relay.. I have had a few differnt electrical items fail that way work for a little then seize/stop unplug it re-start it and agin works for 5 seconds then nada..
Cap'n Krusty |
Nov 5 2009, 12:40 AM
Work the hazard switch about 20 cycles to clean the contacts and see if that helps. The Cap'n
Lo-Fi Version | Time is now: 12th May 2024 - 03:32 PM |
