'74 2.0 Injectors, Source For New Injectors |
914four |
Nov 4 2009, 09:45 PM
Senior Member Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States |
I tried the classifieds with no luck so I thought I would try the garage.
Recently I learned that I have mismatched fuel injectors causing problems and would like to purchase new injectors. There are a few sources I have found with prices around $54.00 for new injectors but after purchasing the last one from one source I have found all of the other sources to be out of stock. Does anyone know of a source with reasonably priced new injectors available? Any information would be appreciated. Kelvin |
detoxcowboy |
Nov 4 2009, 09:50 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Wow, At least you got one cheap $54.00, all the websites say they have them then when you go look they have either nada, aftermarket, or 1.8 leftovers ect.. there was somebody selling about 2 weeks ago 4 almost new less than 1,000 miles 4 of them for $450.00, I got a set ebay $500.00. Seems like the rule of thumb is collect 5 or 6 used to get 4 good ones.. Maybe by posting here someone will break loose with their stash. I sold an NOS original for $125.00 so at least you got one.. three to go.
dr914@autoatlanta.com |
Nov 5 2009, 08:28 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
wow I guess that it is about time to raise our 80 dollar retail then.
tod914 |
Nov 5 2009, 09:47 AM
The websites don't reflect the inventory. The places I tried all said they are out of stock. Unless Bosch is making new ones, I would think they are pretty much gone at this point.
zymurgist |
Nov 5 2009, 09:51 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
How about acceptable interchange parts? Surely there must be some injectors out there that will do the trick.
tod914 |
Nov 5 2009, 09:52 AM
There was a post some time ago regarding that. I think Jeff Bowsby has a chart on the flow rates, etc.
914four |
Nov 5 2009, 09:58 AM
wow I guess that it is about time to raise our 80 dollar retail then. Are the 80 dollar injectors new? I usually start with Auto Atlanta but when I called I was told new injectors were no longer available. After reading about some members experiences with rebuilt injectors I was hoping to find new but it looks like I may have to go with the rebuilt injectors. A local source said they could get a set of new injectors but it would be about $1000.00 for four injectors and that sounded excessive so I started an internet search and have only been able to come up with one new injector. I'm not sure the potential problems with rebuilt injectors is worth avoiding the $1K cost of a new set and I'm not sure sure if the local source can really come up with the new injectors if I placed an order. I would like to install four known good injectors and that might be impossible to do even with new so I will probably take my chances with the one new injector and three rebuilt. Kelvin |
tod914 |
Nov 5 2009, 10:12 AM
The new ones were going for about $225.00+ each before that huge drop in price. Maybe they were clearing the last of the inventory for that $54.00 price. Witchhunter is a good place to get them cleaned and calibrated. Not that expensive either.
kconway |
Nov 5 2009, 12:31 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
You may be able to source them from South America if you know anyone down there that can check. I've been told there is alot of Bosch stuff still on the shelf down there.
tracks914 |
Nov 5 2009, 12:43 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I went through this 4 months ago. I ended up finding a bad set then a good set of used ones on this site.
The $54 ones are not Bosch but can still work great IF you can find them. I could only find one and wasn't going to buy just one. I have 8 Bosch used ones that I might send to Witch hunter for rebuild and then sell them, but for now I'll hang on to them. BTW there is a Mercedes 73-75 injector that is identical to the 914 but with a straight hose. Search this site and you will find them. I could only find 2 of the Mercedes at the time. |
Drums66 |
Nov 5 2009, 01:33 PM
You may be able to source them from South America if you know anyone down there that can check. I've been told there is alot of Bosch stuff still on the shelf down there. Correct......Brazil is 1 of them! (IMG:style_emoticons/default/idea.gif) |
Drums66 |
Nov 5 2009, 01:39 PM
Chile and Argentina are a couple other's (IMG:style_emoticons/default/idea.gif)
914four |
Nov 5 2009, 06:55 PM
The $54 ones are not Bosch but can still work great IF you can find them. I recently purchased a new in the box Bosch fuel injector with the correct part number for $54.00. Apparently the price dropped significantly just before they were NLA and if you do a web search you can still find a few places that advertise this low cost for the new Bosch fuel injectors. I have not been able to find any more of the new injectors in stock with this cost. |
Nov 5 2009, 07:10 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It seems it wouldn't be too difficult to retrofit a stock fuel-rail to accept more modern, easily available and reasonably priced fuel injectors ...
(IMG:style_emoticons/default/idea.gif) Andy |
underthetire |
Nov 5 2009, 07:26 PM
It seems it wouldn't be too difficult to retrofit a stock fuel-rail to accept more modern, easily available and reasonably priced fuel injectors ... (IMG:style_emoticons/default/idea.gif) Andy It's harder than you think ! I'm doing some right now. Using a Delphi two port one. 1. had to make brass sleeves. The new injector tips are larger, so just drilling out the manifolds wouldn't work. Not enough surface area to get a good o-ring seal. 2. Drill out the manifolds and solder in the sleeves. 3. Make fuel rails to fit over the injectors. New injectors use an o-ring on top instead of the hose. 4 make clamps to hold the fuel injector rail down to the maifolds to hold it and the injectors in. 5. adjust fuel pressure cause of the change in injector caracteristics. Now for me, tuning is easy with the megasquirt, simply adjust map/fuel bins and injector time. I'm going one step further and building a new plenum for my new 50 mm throttle body with idle circuit control. Thats not to say some other injector wouldn't be a closer match IDK, but then there is the impedance (resistance basicaly) of the injectors to deal with then. Did I muddy it up enough? (IMG:style_emoticons/default/beer3.gif) |
jimkelly |
Nov 5 2009, 07:48 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
kconway |
Nov 6 2009, 12:59 AM
I scored a set of 4 new in box off ebay back in May for $355. (IMG:style_emoticons/default/laugh.gif)
They come up on ebay every once in awhile. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:30 AM |
