Cable Shifter, why are these so hard to find? |
TimMartin |
Apr 3 2003, 04:51 PM
Newbie Group: Members Posts: 45 Joined: 16-January 03 From: Morgan Hill, CA Member No.: 157 Region Association: None |
I'm interested in cable shift kits, which the way i figure it don't have to be Porsche specific. I'm thinking about fabricating the parts necessary to make a tailshift tranmission run with a race-style cable shifter.
The problem is all i can find are shifters for automatics. I'm guessing web research isn't going to cut it. Things this specific are often hard to find. With that said, I was going to do this for just the standard 901, but perhaps such solutions don't exist unless you're running a 915? |
Brad Roberts |
Apr 4 2003, 01:55 AM
Tim,
build your own and use the Boxster shifter and cables. This shifter (and cables) have been well proven in racing (GT3RS and Carrera cup use the same shifter w/ shorter cables) The Boxster/996 shifter will work perfect on top of the center tunnel. I know you have the ability to do this. The main hack part of Eric's (in my opinion) is the shifter. The way a Boxster shifter works ....is trick. Fairly cheap too. B |
Lo-Fi Version | Time is now: 17th May 2024 - 01:48 PM |
