POR15 over existing paint, ever done it? |
Doug Leggins |
Mar 17 2004, 10:57 AM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I have been planning to use POR15 on the entire underside of my car. That is up unitl about 2 days ago. About a month ago we painted a couple of small areas on the tub. One area over bare metal and one area over existing paint. The existing paint area was scuffed, marine cleaned and metal ready was applied and then the POR15. I decided to strip part of the POR in the 2 areas just to see how well it had adhered. The POR over the bare metal had good adhesion. The POR over the prepped paint did not. Once I started stripping the POR it started peeling off in strips 1/2" - 2" long. Wasn't expecting that!!!
I had called the POR 15 place about 2 months ago and spoke to them about painting the POR15 over existing paint/undercoating. Got a standard line of its designed to be most effective on bare properly prepped metal. They said it may adhere well to paint/undercoating, it may not. My experience so far is that it does not stick to the existing paint on the bottom of the tub. Has anyone else used POR15 over existing original paint on there 914 with success? I am currently looking at using a Sherwin Williams Epoxy Primer on the tub instead of the POR15. This was a recommendation from a local restoration shop that has used this product successfully on several cars. Anyone in this group used an Epoxy Primer? TIA |
SirAndy |
Mar 17 2004, 12:26 PM
Resident German Group: Admin Posts: 41,626 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(kellzey @ Mar 17 2004, 09:11 AM) It needs to be to rust or prepped metal. It is not designed to chemically bond to paint or primer. that is correct, BUT he said he used metal ready on the surface first. which "should" work because the por-15 will adhere good onto the metal-ready UNLESS you didn't wash off the metal ready with water first, before you painted it with por-15! i had the same problem on my car where i used metal-ready and didn't wash off excess before painting with por-15. it would just come off in flakes and not bond. if you wash off the excess metal-ready first, it'll stick ... Andy <-- who did the complete interior with MR/POR-15! (IMG:http://www.sirandy.com/pix/914/2003.05.19/IMGP2088.JPG) |
Lo-Fi Version | Time is now: 11th May 2024 - 08:57 AM |
