Ed is the the Throttle Body we need? |
rick 918-S |
Nov 14 2009, 10:18 PM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I finally had some time to remove the intake from the 411 parts engine I have. Is this the intake and throttle body we need? If so where do I send it?
ejm |
Nov 15 2009, 06:22 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,690 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
It looks like that may be from a car with an auto trans. Will a regular barrel nut fit where the throttle cable attaches? Otherwise it should be the same. Dwayne says the throttle switch is ok so it's only the housing that's needed.
rick 918-S |
Nov 15 2009, 08:46 AM
Yes, It may have been an auto car. I think I'll post in the garage and see if anyone can post a photo of the linkage so maybe I can tell if this one will work or adapt.
rick 918-S |
Nov 15 2009, 10:31 AM
Ed, You are the man! I just went out and looked over that engine. It has an auto flywheel on it. I removed the jesus clip on on the end of the spring and slid the linkage tube off. The pivot pin slides up and out of the throttle body linkage mount leaving a large hole for a barrel nut I think. I'll get another photo with the parts off.
rick 918-S |
Nov 15 2009, 11:05 AM
Update: I posted in the garage. Sean posted a photo that confirmed the linkage connection is all wrong. I did get the gasket off though and it's perfect! Where do I send this?
ejm |
Nov 18 2009, 08:48 PM
Rick - I'll get an address from Dwayne when I talk to him tomorrow. After we talked I went up in the garage and found a throttle body I'll send out. We still need to find the boot from the TB to the air filter.
rick 918-S |
Nov 18 2009, 10:24 PM
Very cool! (IMG:style_emoticons/default/clap23.gif)
Kansas 914 |
Nov 19 2009, 04:56 PM
Rick - I'll get an address from Dwayne when I talk to him tomorrow. After we talked I went up in the garage and found a throttle body I'll send out. We still need to find the boot from the TB to the air filter. Ed, Is this the right boot? Now at $17 on greed bay... http://cgi.ebay.com/ebaymotors/ws/eBayISAP...ASS%3AUS%3A1123 Here is a picture from my 1.7L - they look the same to me. |
ejm |
Nov 19 2009, 09:48 PM
Looks like the correct boot. I keep thinking I've got one somewhere, gotta take another look.
Got Dwayne's voicemail today so I'll try him again tomorrow. |
rick 918-S |
Nov 19 2009, 09:51 PM
Rick - I'll get an address from Dwayne when I talk to him tomorrow. After we talked I went up in the garage and found a throttle body I'll send out. We still need to find the boot from the TB to the air filter. Ed, Is this the right boot? Now at $17 on greed bay... http://cgi.ebay.com/ebaymotors/ws/eBayISAP...ASS%3AUS%3A1123 Here is a picture from my 1.7L - they look the same to me. That looks right to me. 5 days to go though. 8 bucks shipping. |
Kansas 914 |
Nov 21 2009, 07:32 AM
That looks right to me. 5 days to go though. 8 bucks shipping. OK - I have an automatic snipe sitting on it - don't bid against me! I also have a question into the seller (I have bought from him before) making sure it isn't cracked. There is also a console wiring harness - we will need it since we are adding a console. |
rick 918-S |
Nov 21 2009, 05:56 PM
question into the seller (I have bought from him before) making sure it isn't cracked. There is also a console wiring harness - we will need it since we are adding a console. Cool, I will pull the console and get it ready to ship. |
tat2dphreak |
Nov 21 2009, 09:09 PM
is she going with stock gauges? if so I may have some, I went with modern gauges... you know with silly things like NUMBERS (IMG:style_emoticons/default/tongue.gif)
ejm |
Nov 22 2009, 06:15 AM
Talked with Dwanye Friday night. He plans to get started on the engine this week. He says to ship the TB and gasket to Mary and he will install them when he brings the engine over.
He mentioned that when the engine was removed that several things had been cut. He remembered the throttle cable (new one on list) and ground strap had been cut and thought there was something else. Hopefully not a wiring harness. He went on a bit about when the engine is finished he plans to install the engine/trans and fire it up. Doing the install is one thing but the car would need to be fairly along in the assembly process (electrical/fuel) to get the engine running. He could do the install and come back build weekend to fire it up. |
Kansas 914 |
Nov 22 2009, 02:45 PM
Talked with Dwanye Friday night. He plans to get started on the engine this week. He says to ship the TB and gasket to Mary and he will install them when he brings the engine over. He mentioned that when the engine was removed that several things had been cut. He remembered the throttle cable (new one on list) and ground strap had been cut and thought there was something else. Hopefully not a wiring harness. He went on a bit about when the engine is finished he plans to install the engine/trans and fire it up. Doing the install is one thing but the car would need to be fairly along in the assembly process (electrical/fuel) to get the engine running. He could do the install and come back build weekend to fire it up. Thanks Ed, You are right - the car will not be wired until the build weekend. The wiring harness is in now place but Mary purchased an Engman fuse panel that will be installed. Mary said that Dwayne was to assess the clutch pressure plate and disk to make sure they were good before he mated the engine/transaxle. |
Kansas 914 |
Nov 22 2009, 02:46 PM
is she going with stock gauges? if so I may have some, I went with modern gauges... you know with silly things like NUMBERS (IMG:style_emoticons/default/tongue.gif) Rick - does your console have gauges? |
rick 918-S |
Nov 22 2009, 05:12 PM
is she going with stock gauges? if so I may have some, I went with modern gauges... you know with silly things like NUMBERS (IMG:style_emoticons/default/tongue.gif) Rick - does your console have gauges? Yes. I think it's complete and still in the car. Let me get a photo of it. I have to wait until Daylight. It's in my storage garage and the lighting sux. |
Kansas 914 |
Nov 22 2009, 06:12 PM
is she going with stock gauges? if so I may have some, I went with modern gauges... you know with silly things like NUMBERS (IMG:style_emoticons/default/tongue.gif) Rick - does your console have gauges? Yes. I think it's complete and still in the car. Let me get a photo of it. I have to wait until Daylight. It's in my storage garage and the lighting sux. If Mary has the center arm rest - does the console still fit? |
tat2dphreak |
Nov 22 2009, 06:40 PM
QUOTE If Mary has the center arm rest - does the console still fit? yep, does in mine anyway.you are talking about the box with the arm-rest hinge, right? |
Kansas 914 |
Nov 23 2009, 08:19 AM
QUOTE If Mary has the center arm rest - does the console still fit? yep, does in mine anyway.you are talking about the box with the arm-rest hinge, right? Yep - I didn't know if they were a different length with the console - I think they are the same. I also got this reply from the Pete on the eBay item (TB boot): Hello Mike, I pulled this boot this am, it is in good used condition, no rips. Regards, Pete I will make sure we win this (withinreason)... This is going to be so cool! |
Lo-Fi Version | Time is now: 6th May 2024 - 03:31 AM |
