Can someone help me with a photo of a 1.7 TB? |
rick 918-S |
Nov 15 2009, 08:54 AM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I have a throttle body that can off a 1.7 from 411 VW. The linkage connection is different. Ed Morrow thinks it's from an auto trans car. Can anyone go out to the garage and take a photo of the linkage connection on their 1.7 throttle body?
I need to figure out if the only difference is the barrel nut connection and if I can remove the linkage connection and install the 914 style barrel nut connection. Attached image(s) |
sean_v8_914 |
Nov 15 2009, 10:23 AM
dfg
rick 918-S |
Nov 15 2009, 10:39 AM
dfg Thanks Sean! That was the exact angle I was looking for! (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/biggrin.gif) I will take a photo of the one I have from the same angle. I think the one I have has a larger hole where the barrel fitting mounts. It may require a bushed fitting. Otherwise I think it will work. |
rick 918-S |
Nov 15 2009, 10:52 AM
Crap! The linkage connection is all wrong! I was going to send this to the guy building the engine for Mary Shortridges brothers car. (IMG:style_emoticons/default/dry.gif)
rick 918-S |
Nov 15 2009, 11:02 AM
On a brighter note I did end up with a perfect NLA gasket for the project! (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 05:39 AM |
