Question: Plastic clips for fuel lines in engine compartment, etc. |
x98boardwell |
Nov 20 2009, 07:04 PM
Member Group: Members Posts: 62 Joined: 14-October 09 From: Central Valley, CA Member No.: 10,935 Region Association: None |
I am looking for the rubber angled grommets that are found under the battery tray of a 914 which hold the fuel lines steady and from cutting themselves on the metal as they pass through the sub-frame on there way up to meet with the fuel lines that supply the injectors.
Are they still available? If not, what do you/I use now? Also, can we still buy the plastic clips which snap into the firewall and hold the fuel lines as well? Mine are white/clear plastic and are very brittle... I own a 75 914 2.0 Thanks in advance, Bryan |
Lo-Fi Version | Time is now: 29th May 2024 - 11:01 PM |
