brain test |
brain test |
oldschool |
Nov 23 2009, 11:56 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
I was working on putting new gas lines and I notice that my brain was full of old white powder (battery stuff) are they bullet prof or sensitive? and how can I check if it works?
McMark |
Nov 24 2009, 12:23 AM
You can shop on eBay for a tester. There were a few companies that build crude testers for them. More info should be available on Brad Anders site.
Elliot Cannon |
Nov 24 2009, 01:59 AM
NOT a good idea to run gas lines through your brain. (IMG:style_emoticons/default/lol-2.gif)
tod914 |
Nov 24 2009, 07:57 AM
Pelican rents them I believe... not brains, the testers to see if yours still functions (IMG:style_emoticons/default/tongue.gif) Places like Pelican and Performance Products also see rebuilt ones. Not sure about Pelican, but PP you'll get a year waranty and a 15% PCA discount if that helps.
tradisrad |
Nov 24 2009, 08:16 AM
What ever you do don't go probing around with a mulit-meter.
The "brain" is robust and failure is low. The best bet is to clean it up and put it back in the car and see if it works! If you want to test you components now is the time. Probe them with your mulit-meter from the "brain" harness. You can check the resistance of your injectors, CHT and other components. You can find "how to"s online. But dont probe the brain. |
oldschool |
Nov 24 2009, 11:38 AM
What ever you do don't go probing around with a mulit-meter. The "brain" is robust and failure is low. The best bet is to clean it up and put it back in the car and see if it works! If you want to test you components now is the time. Probe them with your mulit-meter from the "brain" harness. You can check the resistance of your injectors, CHT and other components. You can find "how to"s online. But dont probe the brain. now are the brains unique to each car.I have a 2nd 914 same year and same power plant. (IMG:style_emoticons/default/idea.gif) |
underthetire |
Nov 24 2009, 11:56 AM
What ever you do don't go probing around with a mulit-meter. The "brain" is robust and failure is low. The best bet is to clean it up and put it back in the car and see if it works! If you want to test you components now is the time. Probe them with your mulit-meter from the "brain" harness. You can check the resistance of your injectors, CHT and other components. You can find "how to"s online. But dont probe the brain. now are the brains unique to each car.I have a 2nd 914 same year and same power plant. (IMG:style_emoticons/default/idea.gif) Should be the same. The "brain" is just logic TTL comparison circuits, no memory involved like a new computer. They are pretty solid unless you see traces gone or components burnt. |
Nov 24 2009, 07:26 PM
I have the Bosch tester ......you pay shipping both ways...use it till your done.
Rich |
championgt1 |
Nov 24 2009, 09:45 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
I have the Bosch tester ......you pay shipping both ways...use it till your done. Rich Can't beat that! (IMG:style_emoticons/default/beerchug.gif) |
oldschool |
Nov 24 2009, 10:10 PM
I have the Bosch tester ......you pay shipping both ways...use it till your done. Rich very cool, how does it work? does my car need to be running (IMG:style_emoticons/default/screwy.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 11:39 PM |
