Zach's Winter Project List, 36/37 completed, and it no longer winter, so I am driving now! |
VaccaRabite |
Nov 24 2009, 06:07 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Okay, its time to start my winter projects, and start the thread to keep me motivated and honest.
36/37 complete! And its no longer winter, so thats JUST GOING TO HAVE TO DO! Tasks to complete: 1) Front End Electrics.
Items may be added as found. |
VaccaRabite |
Dec 4 2009, 06:02 PM
Carbs are taken apart for cleaning / repair.
Rebuild kits are ordered. Venturis are ordered. This is the Jetting that Raby suggested I use for my motor: What I need (jake's note): 30 Vent 125 main 200 air F11 55 idle Float height at 10mm closed, 23mm open 2.5 PSI fuel pressure. Zach |
scotty b |
Dec 4 2009, 07:01 PM
(IMG:style_emoticons/default/aktion035.gif) Wish I was closer to help. (IMG:style_emoticons/default/beerchug.gif) You'll be at the Tail of the Dragon run with it right ?? (IMG:style_emoticons/default/poke.gif)
maf914 |
Dec 5 2009, 10:39 AM
Did you mean "The Dragon and His Tail"? (IMG:style_emoticons/default/laugh.gif)
VaccaRabite |
Dec 5 2009, 11:00 PM
800 mile drive for me (one way). Probably more then I could do in a weekend. And it would likely preclude me from doing the ECC, as I can only afford to do 1 event in the fall (914 or otherwise). Zach |
slackin' at work |
Dec 6 2009, 11:41 AM
i should be working Group: Members Posts: 265 Joined: 12-October 07 From: charlottesville, va Member No.: 8,215 Region Association: MidAtlantic Region |
have you done any work on the M715?
VaccaRabite |
Dec 6 2009, 11:48 AM
Not even touched it. (IMG:style_emoticons/default/sad.gif)
Well that's not true. I did string some Christmas lights up on it. Figure since its been on jackstands outside for over a year, I may was well light it up. I keep saying: I'm going to get to that soon. But the 914 is holding my interest more right now, and I can only handle one project at a time right now without digging into my family time. Zach |
VaccaRabite |
Dec 14 2009, 08:08 PM
Well, tonight I took down a big one.
Another layer of RaaMaat installed on the firewall, and a layer put in the doors. I am thinking I might add a layer of ensolite to the firewall as well before I put the back pad back in. But that would require me to buy the ensolite. Zach |
VaccaRabite |
Jan 9 2010, 03:08 PM
Its been simply too cold for me to work lately. So, I went out and bought a 70,000 BTU K1 heater. Not the torpedo type, this is supposed to use radiant and convection heat.
I'll get it going with my radient K1 heater and the IR propane heater and maybe get my garage warm enough to work in w/o wishing I was someplace else. Zach |
VaccaRabite |
Jan 10 2010, 11:11 AM
Heat == good! I actually got work done last night.
Much of the interior is back in. I still need to put in the pass seat and the door panels. But I fixed the drivers seat rail and got that backpad in. Starting to look like a car again. I tore out the Forward flappers and vent housings in prep for the Engman block off kit. I fixed (I think) the oil leak between the remote hose and the oil pressure sender. I am going to make a new sendr holder this afternoon. Progress! Zach |
McMark |
Jan 10 2010, 03:18 PM
Lookin' good! (IMG:style_emoticons/default/mueba.gif)
jsayre914 |
Jan 10 2010, 06:31 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I got your message, did you have your 914 out yesterday??
We should do a starbucks thing before or after work one day soon. I dont have heat yet, but who needs it anyway (IMG:style_emoticons/default/driving.gif) |
VaccaRabite |
Jan 23 2010, 06:14 PM
The new oil pressure sender mount that I made is in, and works perfectly. Grounds the sender to the case, and will also probably clear up the oil leak I had on the top of the motor.
I also got the car up on jackstands in an attempt to keep my tires from flat spotting. I got word from Underthetire that my carb tops are on my way back to me, so I will be able to finish the carb switch probably next weekend. That will be exciting! Also, looking over my list, I am much farther along then I thought I was. Woohoo! Zach |
Cevan |
Jan 23 2010, 07:29 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
The new oil pressure sender mount that I made is in, and works perfectly. Grounds the sender to the case, and will also probably clear up the oil leak I had on the top of the motor. I also got the car up on jackstands in an attempt to keep my tires from flat spotting. I got word from Underthetire that my carb tops are on my way back to me, so I will be able to finish the carb switch probably next weekend. That will be exciting! Also, looking over my list, I am much farther along then I thought I was. Woohoo! Zach Please post a picture or two of the oil pressure sender mount. |
VaccaRabite |
Jan 23 2010, 07:47 PM
Will have to be tomorrow, as I can't find my little camera, and the big one is unweildy int he teener engine bay.
But it is pretty simple. It is 2 bits of angle iron welded together to make a "C" channel. there is a small piece of thin sheet bent into an "S" and tacked in the center of the channel - this presses against the sender to make sure thre is good ground when everything else is painted. There is a single stand off that bolts to the top of the engine. The sender is held in place with a largeish worm gear clamp. Zach |
VaccaRabite |
Feb 9 2010, 10:10 AM
I bought the Engman vent block off kit. And it got installed on my car last night. It does not come with vent blocks where the fresh air blowers go. I made block-offs out of some of the sheet that Mike had gotten to make engine tin with, and attached them with outdoor rated double sided tape. According to the packaging, the tape will remove the substrate it is attached to before it fails, so I hope they stay put.
Only the passenger seat and the lower dash pad need to be put in before I can cross out that one from my list as well. My list is getting well done! Looking forward to the spring launch. Zach |
VaccaRabite |
Feb 16 2010, 03:46 PM
My list is 75% done.
I forgot to update when I put my carbs back on the car. They won't get balanced until things warm up a little and I can open the garage so I don't gas myself. Door hardware and the front spoiler should be here soon, so I will be able to kick them off the list soon too! Zach |
ghuff |
Feb 16 2010, 03:59 PM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
Keep cracking.
Once I get the GTi's latest problems smashed it is back to my 914 metal work. |
Cevan |
Feb 16 2010, 04:24 PM
Carbs are taken apart for cleaning / repair. Rebuild kits are ordered. Venturis are ordered. This is the Jetting that Raby suggested I use for my motor: What I need (jake's note): 30 Vent 125 main 200 air F11 55 idle Float height at 10mm closed, 23mm open 2.5 PSI fuel pressure. Zach Do you mean 32mm open? I just did this yesterday and Weber recommends 32mm open. |
Feb 16 2010, 05:21 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Zach's Winter Project List Are you done yet? (IMG:style_emoticons/default/poke.gif) Winter is over ... (IMG:style_emoticons/default/piratenanner.gif) Andy |
VaccaRabite |
Feb 16 2010, 06:14 PM
Zach's Winter Project List Are you done yet? (IMG:style_emoticons/default/poke.gif) Winter is over ... (IMG:style_emoticons/default/piratenanner.gif) Andy I still got got 3 feet of snow on the ground that say otherwise. Getting really close though. At this point I could sync the carbs and be driving tomorrow. The other stuff on the list is "nice" but not exactly "required." But, the car won't see blacktop until mid-march at least. I have a little time still. My goal for "spring" is Hershey Swap in late April. Zach |
Lo-Fi Version | Time is now: 1st June 2024 - 11:56 AM |
