Mirror Idea? What do you think? |
JRust |
Nov 26 2009, 02:15 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay so I have been kicking around an idea for a while. I've seen plenty of different mirrors people have used on their doors. I've seen a few tiny ones more on the small window than the door. I'd really like to see something that is a bolt on but has an extra option to it. So here is my idea
I'd like to replace the small triangle window on the door. I would like to have a nice molded side mirror along the bottom of what used to be the triangle window. Then above add a smaller window that opens on a pivot. Like you used to find on older trucks to bring air into the cab. Not sure what they called that window but does this make sense? I have a picture of it in my mind but nothing on paper yet? I am sure this will take plenty work. Just seems like it would be doable. Maybe I'm nuts but I think taking off the original window. You could fab up what was needed into it's spot on the same window channel? (IMG:style_emoticons/default/confused24.gif) |
burton73 |
Nov 26 2009, 02:21 PM
burton73 Group: Members Posts: 3,526 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Okay so I have been kicking around an idea for a while. I've seen plenty of different mirrors people have used on their doors. I've seen a few tiny ones more on the small window than the door. I'd really like to see something that is a bolt on but has an extra option to it. So here is my idea I'd like to replace the small triangle window on the door. I would like to have a nice molded side mirror along the bottom of what used to be the triangle window. Then above add a smaller window that opens on a pivot. Like you used to find on older trucks to bring air into the cab. Not sure what they called that window but does this make sense? I have a picture of it in my mind but nothing on paper yet? I am sure this will take plenty work. Just seems like it would be doable. Maybe I'm nuts but I think taking off the original window. You could fab up what was needed into it's spot on the same window channel? (IMG:style_emoticons/default/confused24.gif) I had that vent window on my 72 VW Beatle. Look on the Beatle Convertibles to see how it held the top pivot in the frame. You need a Beatle Convertible vent frame. Bob |
jmmotorsports |
Nov 26 2009, 02:22 PM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
It's doable, you would have to use Plex or Lexan since you can't cut the tempered glass. Maybe some of the early 911 parts could work,they had opening vent windows.
Jerry |
jt914-6 |
Nov 26 2009, 02:41 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Here's my plan that I haven't done yet. I plan to make Lexan windows and mount these mirrors to it. No "vent" window to pop out, but the mirrors should work.
http://www.pegasusautoracing.com/productde....asp?RecID=1553 |
Bruce Hinds |
Nov 26 2009, 02:57 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Okay all you yard dogs....
I had the same idea. There are plenty of nice looking mirrors that I think would work fine mounted into what is now the little triangle window.(that was called a vent window, or also a wing window BTW) Replacing that with lexan would allow you to drill through for mounting the wires for electrical adjusting mirrors if needed. My mother has a 95 buick century waggon that has some interesting shaped mirrors that I think would look good on my car. For a more rounded shape for you flared guys, our Sebring mirrors would look sharp. The key is to find some that have about the same size triangle shape where they mount, or perhaps a little larger where the plastic can be trimmed to fit. I'd love to know if any one has found some that will fit and I'd love to see some pics if anyone has done this..... B |
jmmotorsports |
Nov 26 2009, 04:11 PM
Okay all you yard dogs.... I had the same idea. There are plenty of nice looking mirrors that I think would work fine mounted into what is now the little triangle window.(that was called a vent window, or also a wing window BTW) Replacing that with lexan would allow you to drill through for mounting the wires for electrical adjusting mirrors if needed. My mother has a 95 buick century waggon that has some interesting shaped mirrors that I think would look good on my car. For a more rounded shape for you flared guys, our Sebring mirrors would look sharp. The key is to find some that have about the same size triangle shape where they mount, or perhaps a little larger where the plastic can be trimmed to fit. I'd love to know if any one has found some that will fit and I'd love to see some pics if anyone has done this..... B Bruce, Here's mine. Jerry Attached image(s) |
JRust |
Nov 26 2009, 04:21 PM
I love the look of yours Jerry. I'd just like one that sticks out a little further. I like the vent window as an option when it's cold & I have my top on. Really like to have a bigger mirror there without it looking goofy (IMG:style_emoticons/default/dry.gif)
Nov 26 2009, 04:29 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What do you think? I think you need to buy another 914 now! So you don't have time to come up with more crazy ideas ... (IMG:style_emoticons/default/biggrin.gif) Andy |
jmmotorsports |
Nov 26 2009, 04:30 PM
I love the look of yours Jerry. I'd just like one that sticks out a little further. I like the vent window as an option when it's cold & I have my top on. Really like to have a bigger mirror there without it looking goofy (IMG:style_emoticons/default/dry.gif) When you have a V8 everyone is behind anyway,dose not matter if you can see them or not. Jerry |
boxstr |
Nov 26 2009, 05:07 PM
JR If you want to go the 911 or 944 look, let me know I have a bunch of those exterior mirrors.
Craig C. Laughlin CAMP 914 |
JRust |
Nov 26 2009, 06:20 PM
What do you think? I think you need to buy another 914 now! So you don't have time to come up with more crazy ideas ... (IMG:style_emoticons/default/biggrin.gif) Andy (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) Thanks Andy! That was definately good for a laugh (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 07:12 PM |
