V8 Water Pump Belt Woes, V8 GUYS, Water pump belt under the shift rod coupler? |
wallys914 |
Nov 27 2009, 12:57 PM
In life you don't get what you want, you get what you negoia Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
I have the engine installed and have already fired it up, just need to get the shifting perfect before driving, Issue.
The shift rod coming out of the car, connects to the modified shift rod, but is above the water pump belt and is pushing on it when moving through gears. I have thought of several option to rig it to work, but does any one have any ideas, as to resolve this issue? or has any one had this issue, with the shift rod Above the WP belt? Thanks |
Lo-Fi Version | Time is now: 19th May 2024 - 12:18 PM |
