Trans Dripping, How long to refil? |
bandjoey |
Nov 27 2009, 01:29 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Here's a pix of a weeks worth of drips from the rear of the tranny. It's a slick about 12" x 8" At this rate, how often should I top off? Is resealing the rear an easy, medium, or hard task for the average goofball 914 mechanic?
Happy Thanksgiving Ya'll and a Merry Christmas Season! Bill Attached image(s) |
Nov 27 2009, 01:38 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Where is it coming from? (IMG:style_emoticons/default/confused24.gif)
Spoke |
Nov 27 2009, 01:39 PM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
When mine leaked like that, it was the seal around the speedo cable angle drive.
If you're worried about losing oil, top off the tranny every now and then. |
Dr Evil |
Nov 27 2009, 02:09 PM
Most often the O-ring on the speedo. I stock these for cheap. Easy to replace.
orange914 |
Nov 27 2009, 03:00 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Most often the O-ring on the speedo. I stock these for cheap. Easy to replace. thats next on the 73, maybe someone can do a write up to the "tech articles" on it (IMG:style_emoticons/default/beerchug.gif) |
Dr Evil |
Nov 27 2009, 03:02 PM
I think you are correct. It is an easy fix unless the bore is gouged. Then you need to fix it. I can show how.
bandjoey |
Nov 29 2009, 08:50 AM
OK.It's leaking at the speedo. Also, the base of the mount is wobbly...I can push it back in forth on the shaft. Is this normal or is the drive worn out?
Dr. I will need the seal and instructions. I'm PMing later today to get that. Thanks Bill Attached image(s) |
jt914-6 |
Nov 29 2009, 08:58 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Bill. I think the major problem with the leak is the TEXAS licence plate...... (IMG:style_emoticons/default/biggrin.gif)
bandjoey |
Nov 29 2009, 10:47 PM
If it were just the Texas plates, we'd have already sealed up that hole! Like this one.
September 27 2008, Arkansas at Texas - L 52-10 Too bad the schedule was changed for Arkansas to play TCU in 2012...instead of 2009...What a game that would have been! JT, I'll mail you a set of Gosh Durn Big Awful Blasted Texas plates when you come down here, so we cowboys won't hurt you'all'ens. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) Bill |
Lo-Fi Version | Time is now: 19th May 2024 - 06:29 PM |
