Powered washer fluid assembly |
swood |
Nov 29 2009, 07:40 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Ok, so I'm mocking up what I have for this assembly and referencing Andy's write up
I have a few questions and I'll post a few pics. First, when I pulled out the filler tube, it basically crumbled on me. All I have at the moment are zip ties, but here's my modification. I suppose by the time I power it up, if it leaks I can get a better hose clamp. By bypassing the spare tire connection, I can run this tubing right to the pump itself. Can I mount my pump in this area? I have a new Bosch relay p/n # 0 332 019 150-010. It looks like it would go here. No clue on how to wire to it yet. |
swood |
Nov 30 2009, 10:12 PM
Ok, i see my first error. There won't be any new tube connected to the top opening of the water tank, only from the bottom to the intake portion of the pump. The cap needs a hole drilled for air intake. Output side of pump goes to the nozzles. Simple as that. So is does the cap have a check valve that closes the port when there is no tube connected to it (the one connected to the spare tire)?
And thanks for the link to Spokes post Dave...I knew about that one but couldn't find it. Now, on to the switch and wiring... |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:21 AM |
