Powered washer fluid assembly |
swood |
Nov 29 2009, 07:40 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Ok, so I'm mocking up what I have for this assembly and referencing Andy's write up
I have a few questions and I'll post a few pics. First, when I pulled out the filler tube, it basically crumbled on me. All I have at the moment are zip ties, but here's my modification. I suppose by the time I power it up, if it leaks I can get a better hose clamp. By bypassing the spare tire connection, I can run this tubing right to the pump itself. Can I mount my pump in this area? I have a new Bosch relay p/n # 0 332 019 150-010. It looks like it would go here. No clue on how to wire to it yet. |
914Sixer |
Jan 26 2020, 03:33 PM
914 Guru Group: Members Posts: 8,889 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You will have to match the wire location of the aftermarket switch to old factory switch and write down the wire colors to know how wires lay in old tray.
You have to use the old 5 pin tray 7pin is too thick to go in 72-74 housing. Not sure if 7 pin will fit later 75-76. |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:04 PM |
