Powered washer fluid assembly |
swood |
Nov 29 2009, 07:40 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Ok, so I'm mocking up what I have for this assembly and referencing Andy's write up
I have a few questions and I'll post a few pics. First, when I pulled out the filler tube, it basically crumbled on me. All I have at the moment are zip ties, but here's my modification. I suppose by the time I power it up, if it leaks I can get a better hose clamp. By bypassing the spare tire connection, I can run this tubing right to the pump itself. Can I mount my pump in this area? I have a new Bosch relay p/n # 0 332 019 150-010. It looks like it would go here. No clue on how to wire to it yet. |
RickS |
Jan 26 2020, 10:07 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Wow, rather than dealing with mounting the stalk switch and the wiring issues, I just installed a Radio Shack push on spring switch with an in-line fuse and was done with it. It looks like it belongs right next to the pull-on switches. Might just be too simple.
The advice here how to do it properly is spot on though. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:02 AM |
