Powered washer fluid assembly |
swood |
Nov 29 2009, 07:40 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Ok, so I'm mocking up what I have for this assembly and referencing Andy's write up
I have a few questions and I'll post a few pics. First, when I pulled out the filler tube, it basically crumbled on me. All I have at the moment are zip ties, but here's my modification. I suppose by the time I power it up, if it leaks I can get a better hose clamp. By bypassing the spare tire connection, I can run this tubing right to the pump itself. Can I mount my pump in this area? I have a new Bosch relay p/n # 0 332 019 150-010. It looks like it would go here. No clue on how to wire to it yet. |
FlacaProductions |
Jan 29 2020, 06:53 PM
Senior Member Group: Members Posts: 1,594 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
that should be correctly plumbed - the one with the barb goes to the nozzles because of the pressure outgoing.
is the tank vented so a vacuum isn't created? how long did you run it? Is it below the tank? |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:48 PM |
