> rust removal, can't get the tight spots
nycchef
post Nov 30 2009, 09:16 PM
Post #21
mechanical moron
got 90% of the rust off my front nsuspension using a grin dong wheel and wire brush. can't get those hard to reach spots like corners, seams and such. used a half a dozen dremel bits. anyone know a good method. i can't get to a bead blaster right now and would like to finish.
nycchef   rust removal   Nov 30 2009, 09:16 PM
McMark   Go get a gallon of muriatic acid and a plastic con...   Dec 1 2009, 01:14 PM
r_towle   If you have air...get a tool called a spot blaster...   Dec 1 2009, 02:36 PM
Cevan   If you have air...get a tool called a spot blaste...   Dec 1 2009, 02:54 PM
nycchef   If you have air...get a tool called a spot blaste...   Dec 1 2009, 02:57 PM
Vacca Rabite   I am interested to hear more about using your ...   Dec 1 2009, 05:14 PM
rjames   I am interested to hear more about using your ...   Dec 1 2009, 06:27 PM
nycchef   I am interested to hear more about using your ...   Dec 2 2009, 07:29 AM
Greg44   I am interested to hear more about using your ...   Dec 2 2009, 07:38 AM
nycchef   [quote name='nycchef' post='1245307' date='Dec 2 ...   Dec 2 2009, 07:43 AM
Greg44   [quote name='nycchef' post='1245307' date='Dec 2...   Dec 2 2009, 08:43 AM
nycchef   finally a serious participant. have you used eith...   Dec 2 2009, 09:49 AM
kwales   If yer going to acid dip, I'd buy a box of bak...   Dec 2 2009, 10:06 AM
warrenoliver   How about a needle scaler? Never used one but I t...   Dec 2 2009, 10:08 AM
nycchef   How about a needle scaler? Never used one but I ...   Dec 2 2009, 10:29 AM
Gint   [quote name='warrenoliver' post='1245367' date='De...   Dec 3 2009, 09:24 AM
Dr Evil   Try harbor freight for a needle scaler. They are b...   Dec 2 2009, 12:04 PM
charliew   You can put a clear coat over the rubber under coa...   Dec 2 2009, 01:16 PM
Dr Evil   Regarding muriatic acid (found at your local pool ...   Dec 2 2009, 02:37 PM
nycchef   Regarding muriatic acid (found at your local pool...   Dec 3 2009, 07:26 AM
9146986   Go to Home Depot and get "Must For Rust...   Dec 3 2009, 07:56 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:14 PM
