What kind of steering rack/ tie rod set up is this?, and where do I get new boots and rubber bits? |
wayne1234 |
Dec 1 2009, 11:18 AM
Member Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None |
As Always, You always run into something else, when I had the front wheels off doing some welding I noticed the "new tie rod ends" had old rubber put back on . The actually tie rod end does look new but the rubber has not been replaced and the boots going to the steering rack are barley there rotting away... But the rack arms look nice and clean so I just need the boots for that where do I get the boots.. and on the tie rods where do I get the boots for that... Everything I have seen pictures of the tie rods use a "U" shape to connect to the rack,,, this is is a pivot ball ? What do I have going on here? what kind of rack is it it has the following # 914.347.014.01, Thanks
Lo-Fi Version | Time is now: 30th May 2024 - 11:19 AM |
