Pressing out suspension bushings, Brads method instead of burning |
thesey914 |
Mar 19 2004, 02:56 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
QUOTE Don't burn the rubber out if you have a press. It takes me 15minutes per side on the front control arms to push off the old ones. The rear takes about 30 minutes per side to push them out. Quoting Brad from the classic forums on his preferred method of bush removal. Wanting to make a *pro* job of it I want to try this method. The problem is with this I don't think there is much in the way of a surface (other than the splines -not good) to press against. The fronts seem fairly straight forward but its the rears I'm thinking that will be pose problems -J |
Lo-Fi Version | Time is now: 18th May 2024 - 10:52 AM |
