Gas Tank Leaking at the base of the tank where the nipples come out..., Any one had this happen... 2 different tanks? |
wallys914 |
Dec 4 2009, 01:44 AM
In life you don't get what you want, you get what you negoia Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
Last week when I installed the last of the braided fuel line and poured gas in the tank no leak, the engine also didnt fire, at some point I got the engine to fire, the tank starts leaking around the nipples from the base of the tank, no sweat I swaped tanks, 2nd tank leaks in the same place after trying to fire the engine.
WTF (IMG:style_emoticons/default/hissyfit.gif) Any body had this happen to them? 2 tanks? (IMG:style_emoticons/default/confused24.gif) Is it the physics of pressure? Did I miss a ventilation hose some where? I was going to have the nipple welded to the tank, but I want to take the car out this weekend...JB weld it? |
SGB |
Dec 4 2009, 06:52 AM
I had difficulty getting a tight seal on the threads at the nipples. I think I used teflon plumbers tape...
type47 |
Dec 4 2009, 07:54 AM
There are also a couple of sealing gaskets that might be the culpret.
ClayPerrine |
Dec 4 2009, 12:45 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Never had this problem.....
Are you sure your car is not pregnant?? (Leaky nipples....) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/lol-2.gif) |
davesprinkle |
Dec 4 2009, 01:05 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
These fittings don't seal on the threads, so plumber's tape won't work. The fittings use sealing washers. AA sells replacements.
Dec 4 2009, 01:22 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The fittings use sealing washers (IMG:style_emoticons/default/agree.gif) You need the (felt?) washers ... (IMG:style_emoticons/default/shades.gif) Andy |
burton73 |
Dec 4 2009, 01:47 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I was pulling the tank on my blue car yesterday for the V8 as I am going to a SS line. The PO has a very short line on it making it very hard to change it out. This is what they did for there 3.2 6 swap. What is the corect way to deal with the extra line
You can see it looks like it has a weep but not a full on leak. What is the correct way to deal with the extra line if going with a V8 or? Bob |
davesprinkle |
Dec 4 2009, 05:14 PM
I was pulling the tank on my blue car yesterday for the V8 as I am going to a SS line. The PO has a very short line on it making it very hard to change it out. This is what they did for there 3.2 6 swap. What is the corect way to deal with the extra line You can see it looks like it has a weep but not a full on leak. What is the correct way to deal with the extra line if going with a V8 or? Bob, the fittings on the tank need sealing washers. When the washers go bad, they seep fuel just like you've observed on your tank. The sealing washers are NLA from Porsche. AA sells replacement washers, but you should be aware that only 1 of the AA washers will fit correctly. The other AA washer's dimensions allow it to move enough that it might not seat properly, in which case you'll get a leak anyway. For that washer, I cut a new sealing ring from gasket material. Regarding the fuel line length, many people replumb with a loop of additional line so that you can get the tank out. Otherwise, you're forced to make the fuel connections while lying on your back reaching through a tiny access hole as fuel drains into your eye. Which is what I did. And get rid of those worm drive clamps. Immediately. |
736conver |
Dec 4 2009, 05:52 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
You can also go to your local flaps or hardware store and ask for gasket material that can stand up to gas.
SGB |
Dec 4 2009, 05:58 PM
These fittings don't seal on the threads, so plumber's tape won't work. (IMG:style_emoticons/default/mad.gif) And this would explain why I still have a minor weep after my tank R & R... |
bandjoey |
Dec 4 2009, 06:53 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Never had this problem..... Are you sure your car is not pregnant?? (Leaky nipples....) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/lol-2.gif) Yep. I was thinking of Big Nipple Rings like Janet Jackson wears and a little superglue (IMG:style_emoticons/default/aktion035.gif) |
wallys914 |
Dec 4 2009, 11:49 PM
Thanks guys!
Lo-Fi Version | Time is now: 17th May 2024 - 07:47 PM |
