My car refuses to shift into 2 gear, I have no clue were to start |
Apr 3 2004, 08:05 PM
Resident German Group: Admin Posts: 41,612 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Mike9142.0 @ Apr 3 2004, 03:04 PM) It will not come out of the body if the rod is still in it. yepp, you have to detach the shift rod in the front at the shifter and in the back, near the engine mount bar. then, slide out the shift rod towards the back of the car. then pry out the old bushing. then heat up the new bushing in a cupo of water (in the microwave) and hammer it in (use a block of wood, don't hammer on the bushing itself). then, slide the shift rod back in. note: put alotta good grease on the rod/bushing before you slide the rod back in. that should work. then, have gint adjust the whole thing when he gets there (IMG:style_emoticons/default/wink.gif) Andy |
weird_looking_cactus |
Apr 4 2004, 01:04 PM
Cactus Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 |
I got un hooked shift rod bar from the front shifter but now I can't pull the bar from the rear cause it there stuff blocking its way from coming out all the way. There some type of bar that runs across the bottem of the car that I put the jack stands on to hold the car up. Thats what is blocking me.
ChrisFoley |
Apr 4 2004, 02:18 PM
I am Tangerine Racing Group: Members Posts: 7,920 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You can push the rod forward into the tunnel, then when you want to push it back again it is accessible through the little cover near the back of the tunnel, under the plastic tray.
Lo-Fi Version | Time is now: 3rd May 2024 - 04:22 PM |
