picture worth a thousand, thank you's |
F4i |
Mar 19 2004, 11:55 PM
914 DOG! Group: Benefactors Posts: 482 Joined: 22-December 03 From: AB Canada Member No.: 1,460 |
I have the diagrams from pelican for the various hose routings. However it would be very helpful if one of you engine builders would be so kind as to post a few pics of just how things go. I may be missing the odd rubber dodad or 90 deg.this and that. The IPL leaves a lot to be desired. It is a 1974 2.0. TIA
F4i |
Mar 19 2004, 11:59 PM
Oh, I almost forgot. My dizzy has two vacume fittings. The throttle body has two as well but one has been plugged (braised) I believe the plugged one is for retard. Should I clear it , leave it and plug the dizzy, or leave it and not plug the dizzy ( allowing diaphragm travel). Thanks again!
rick 918-S |
Mar 20 2004, 01:39 AM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
can't help but I can bump.
John |
Mar 20 2004, 02:10 AM
What the heck is a dizzy? I don't believe that dizzy is the technical term for distributor. That sounds like a brittish thing..... Perhaps MG's have dizzys? Maybe that is one of the problems with keeping them running.....
You need the 90degree elbow as I believe it also has a smaller nipple with a smaller line attached there. You may be able to fabricate something that works if you can't find the parts. I thought the diagrams were quite self explanatory. There is even a color coded example (I believe) at the Pelican site. |
Bleyseng |
Mar 20 2004, 09:09 AM
Is this what you want?
markb |
Mar 20 2004, 09:28 AM
*sigh* I wish my motor was that clean...... (IMG:style_emoticons/default/sad.gif)
Bleyseng |
Mar 20 2004, 09:41 AM
Yeah, thats a pic of Jeff Bowlsby LE engine (IMG:style_emoticons/default/laugh.gif)
tracks914 |
Mar 20 2004, 10:23 AM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Nice picture, anyone have one of those for a 1.7? Not that I need it yet but.........would be nice to have on file.
F4i |
Mar 20 2004, 12:21 PM
Rich,thanks for the bump.
Bleyseng that's perfect. Thanks! I bought the motor as a long block. The other parts I have collected from a 1.7 and from other people. The pelican site shows the AAR facing the opposite direction of how it actually mounts. The diagram is functional however I was just wondering about routing. Dizzy has and probably always will be slang for distributor. I am not a typist so anything shorter makes life easy. Johnman LUCAS is the problem with keeping them running. Anybody care to comment on the dizzy? (helpfull comments) |
Mar 20 2004, 03:47 PM
The advance fitting points away from the distributor body; the retard points back toward the distributor body.
The advance fitting on the throttle body points toward the distributor; the retard one points back away from the distributor. If your retard fitting on the TB is plugged closed, it's not a bad idea to open it back up again. You may have to fiddle with the idle speed if you do so. --DD |
Bruce Allert |
Mar 20 2004, 04:59 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
WOW! thanks for doing the post Dylan and thanks Geoff for posting the pic. I'll be needing that pic tomorrow when I (I hope) get the 2.0 installed!
Dizzy is an easier way to say/write distributor & that's what I have heard & used since coming into the 914 world. ........b |
Lo-Fi Version | Time is now: 18th May 2024 - 03:39 PM |
