| rick 918-S |
Mar 22 2010, 11:13 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,285 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
As long as I brought this up, a little data for you guys driving cross country with your 4 cylinders. My car is wired and gauged for CHT readings. When I drive normally in traffic with the Raby kit motor the CHT is usually around 275 F. That is until you go to fifth gear. In fifth gear the temperature rises by 50 F. or so. Now with a stockish 2 liter the CHT is about 50 F. higher than the Raby kit motor. So just driving around you sit at about 300 F. Go to 5th gear at highway speed and your temperature rises to 350 F. These temperatures are at a fairly cool ambient of 70 F. and are compensated, so they are actual temperatures. The take home message is if you are on the highway in high ambient temperatures and in fifth, be aware of your oil levels and try to spend some time in forth gear once in a while. I suspect you are ok having your temperatures rise by 50 F. but absolutely do not forget to downshift when you go up a grade. You guys with stock exhaust will have higher CHT. Fan speed seems to have the greatest impact on CHT, but don't let your oil levels drop! Isn't that kind of hot? Do you have a cooler? |
| ConeDodger |
Mar 22 2010, 12:50 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,473 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
As long as I brought this up, a little data for you guys driving cross country with your 4 cylinders. My car is wired and gauged for CHT readings. When I drive normally in traffic with the Raby kit motor the CHT is usually around 275 F. That is until you go to fifth gear. In fifth gear the temperature rises by 50 F. or so. Now with a stockish 2 liter the CHT is about 50 F. higher than the Raby kit motor. So just driving around you sit at about 300 F. Go to 5th gear at highway speed and your temperature rises to 350 F. These temperatures are at a fairly cool ambient of 70 F. and are compensated, so they are actual temperatures. The take home message is if you are on the highway in high ambient temperatures and in fifth, be aware of your oil levels and try to spend some time in forth gear once in a while. I suspect you are ok having your temperatures rise by 50 F. but absolutely do not forget to downshift when you go up a grade. You guys with stock exhaust will have higher CHT. Fan speed seems to have the greatest impact on CHT, but don't let your oil levels drop! Isn't that kind of hot? Do you have a cooler? Jake would have to comment on whether that is hot or not. I suspect it is quite normal for a probe located under the #3 spark plug collar. I do not have a separate cooler and would not have it hooked up to this motor if I did. As I said, fan speed seems to be the biggest contributing factor. I suspect additional oil or an oil cooler would have some small impact but not that dramatic. Any discussion beyond this should probably go to a separate thread. (IMG:style_emoticons/default/idea.gif) |
| RoadGlue |
Mar 22 2010, 12:57 PM
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,034 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California
There's a temp thread started by Jake somewhere here. (IMG:style_emoticons/default/smile.gif)
Speaking of hot temps... for those of you coming from the east and are headed to South Lake Tahoe via Hwy 50 (through Carson City), be advised that the HWY is steep, long and has fast speed limits. The last time I took a 914 up that hill I had to down shift and hold her around 30 mph to keep from over heating. I was monitoring both head and oil temps. Those of you that just have oil temp gauges are missing out on a world of information too. The head temps spiked well before the oil temp gauge showed trouble. Just something to keep in mind. That's the only road I've had trouble on up there and ymmv. (IMG:style_emoticons/default/smile.gif) |
| JRust |
Mar 22 2010, 10:11 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Okay I just registered! Back off Brett (IMG:style_emoticons/default/happy11.gif)
| biosurfer1 |
Mar 22 2010, 10:13 PM
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Ah the power of FB...getting slackers off their asses for 4 years (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif)
| JRust |
Mar 22 2010, 10:23 PM
Ah the power of FB...getting slackers off their asses for 4 years (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) Hey I was at the last 2 WCR. I haven't been gone for 4 years. Not to mention the 914 shootout & just got back from Route 66. I don't recall seeing your lazy ass at either one of those (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) |
| ConeDodger |
Mar 22 2010, 11:06 PM
Ah the power of FB...getting slackers off their asses for 4 years (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) Hey I was at the last 2 WCR. I haven't been gone for 4 years. Not to mention the 914 shootout & just got back from Route 66. I don't recall seeing your lazy ass at either one of those (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) Jamie, You gotta serve donuts. That, he never misses! (IMG:style_emoticons/default/biggrin.gif) |
| ConeDodger |
Mar 23 2010, 07:54 AM
(IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif)
Only 52 days left until the WCR 2010 "Teeners at Tahoe" event! Make your plans early so you don't get left out. So far 36 people are going to be there. Actually over 40 if you count people who we know will be there but haven't registered... Attached image(s)
| ConeDodger |
Mar 24 2010, 09:14 AM
51 days to WCR 2010 "Teeners at Tahoe" Time to plan your route, find out who in your area is going so you can caravan. If all of the beauty at Lake Tahoe was not enough reason to bring a digital camera - we have decided that the drive around the lake on Friday morning will also be a competitive photo rally. You need a partner and you will be given a list of things to get a picture of. No slamming on the brakes or going back is allowed. Besides, if you did slam on the brakes you would have a teener stuffed up your tailpipe! (IMG:style_emoticons/default/blink.gif) If you do that and manage to get all the pictures and are judged to have taken the best pictures - by virtue of your photo rally performance and getting into an accident with two Teeners you could win two awards! The Photo Rally and That Guy! Some of the things you need a picture of will be geographic and specific. Others will be random and quite possibly not come up. For instance, and this will be one of the rally photos you are assigned to get - A Porsche coming the other way. Imagine the Porsche owners surprise to see 40 Teeners coming the other direction and they're all taking pictures of him! (IMG:style_emoticons/default/lol-2.gif) Attached image(s)
| Rand |
Mar 24 2010, 10:54 AM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Hey, I think I recognize the cars in that photo lineup. Tell me how I do:
KevinE, Curt/Greenie, Chris/effutuo101 (before sold to oldschool), and Jim. |
| ScooterD |
Mar 24 2010, 12:19 PM
ScooterD ![]() ![]() Group: Members Posts: 80 Joined: 6-August 06 From: Los Altos, CA. Member No.: 6,589 Region Association: None |
I'm registered and ready to roll! This should be fun, how many people are signed up at this point?
(IMG:style_emoticons/default/driving.gif) |
| McMark |
Mar 24 2010, 12:24 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
33 people as of RIGHT NOW! (IMG:style_emoticons/default/cool.gif)
| biosurfer1 |
Mar 24 2010, 12:34 PM
Not even close Mark! that was the last post....we're up to 41 and counting:)
| jim_hoyland |
Mar 24 2010, 05:13 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,084 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
And the goal is...100 ?
| McMark |
Mar 24 2010, 06:31 PM
| ConeDodger |
Mar 24 2010, 08:45 PM
| ConeDodger |
Mar 25 2010, 09:30 AM
50 DAYS TO GO!!! The 50th top reason to go to WCR2010 "Teeners at Tahoe" is getting to see at least 2 former "That Guy" winners in one place at the same time! Rumor has it that Eric Shea will be there and Jim Tabor is already registered. Tabor is defending "That Guy" champion! Eric Shea hasn't shown the form that won him the honors in years. Will Eric show some signs of contention? Will someone else step up to challenge the champion? You have to register for WCR2010 "Teeners at Tahoe" to find out!!! Attached image(s)
| jimtab |
Mar 25 2010, 08:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
AND, I was training hard last night ( my Friday)....only 32 more working days @ 3 per week.....I am sooooo ready to retire......
| ConeDodger |
Mar 26 2010, 08:13 AM
49 Days to go!!! Well there you go folks! Jim is counting the days until his retirement from both his job and from his "That Guy" championship! Who will step up and challenge? (IMG:style_emoticons/default/biggrin.gif) Attached image(s)
| ConeDodger |
Mar 27 2010, 08:11 AM
[size=4][/size]48 Days to go! Just 4 dozen![/b] The 48th best reason to go to WCR2010 "Teeners at Tahoe" is you can find out what kind of condition your heart is in! That thin air is just like the stress test they give you... Just one rule though! All fun, no chest pain allowed (IMG:style_emoticons/default/biggrin.gif) Attached image(s)
Lo-Fi Version | Time is now: 15th June 2026 - 09:24 AM |
