| rfuerst911sc |
Dec 17 2009, 02:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
When I purchased my 75 rolling chassis I only received one red top key which is the valet key I believe. It works the doors and ignition but it doesn't work the rear trunk or glove box. I'd like to get a black top or master key. When rummaging through the car early on I came across a "card " which says it's a " main key-CLE Principale " and it has a section on the card that has a HC/NC prefix and then 4 digits. I'm guessing this is the key code ? And if it is how do I know it is the correct one for this car ? Lets assume this is the correct key code who can make a key with this information ? Just a dealer ? Any help is appreciated. Thanks
| hwgunner |
Dec 17 2009, 02:06 PM
914 Parts @ Discount Prices 800.321.5432 ![]() ![]() ![]() Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
Get a new black blank and have a key cut from the red key. The cut of the keys are the same, the red key has an extra groove in it to keep it from working the other locks. The new balck key should work everything unless the locks have been changed around.
| ClayPerrine |
Dec 17 2009, 02:50 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Or just pull the locks and have a locksmith key them to work with your red key.
Yes, It works. I have my red 914/6 keyed to the red key, and Betty's orange 914 keyed to the black key. Makes it easy to tell which key to use. |
| rfuerst911sc |
Dec 17 2009, 03:06 PM
Get a new black blank and have a key cut from the red key. The cut of the keys are the same, the red key has an extra groove in it to keep it from working the other locks. The new balck key should work everything unless the locks have been changed around. I did not know that thanks for the idea. (IMG:style_emoticons/default/beerchug.gif) |
| markb |
Dec 17 2009, 03:26 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
Or just pull the locks and have a locksmith key them to work with your red key. Yes, It works. I have my red 914/6 keyed to the red key, and Betty's orange 914 keyed to the black key. Makes it easy to tell which key to use. To do that, take them apart yourself & take out the wafer that has a "ledge" in the center, file out the "ledge", and it will work with the red key (you need a really small file) |
| Eric_Shea |
Dec 17 2009, 05:37 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Valet key's also limit the power to 25hp...
Talk amongst yourselves. |
| orange914 |
Dec 17 2009, 08:43 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
i don't have the "red" key, so it sounds like all i'd have to do is copy my black key onto a red blank??? walla???
mike |
| markb |
Dec 17 2009, 08:52 PM
Yup (IMG:style_emoticons/default/smile.gif)
| Krieger |
Dec 17 2009, 09:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,880 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
QUOTE ??? walla??? I used to go into French class in 9th grade and say Bangjore madame kidde. I wish I new this then. |
| Eric_Shea |
Dec 17 2009, 09:48 PM
QUOTE I wish I new this then It's a town in Canaduh... they speaks the French, no? Walla! (IMG:style_emoticons/default/av-943.gif) |
| orange914 |
Dec 17 2009, 09:53 PM
QUOTE ??? walla??? I used to go into French class in 9th grade and say Bangjore madame kidde. I wish I new this then. easy now (IMG:style_emoticons/default/slap.gif) |
| rfuerst911sc |
Dec 18 2009, 02:41 PM
I looked on Pelican and they want $25.00 per blank for the black top (IMG:style_emoticons/default/dry.gif) does anyone sell them for a reasonable price ?
| Phoenix-MN |
Dec 18 2009, 02:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
I looked on Pelican and they want $25.00 per blank for the black top (IMG:style_emoticons/default/dry.gif) does anyone sell them for a reasonable price ? I had some made at the local Porsche dealer, $10 IIR correctly Paul |
| McMark |
Dec 18 2009, 03:04 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Lo-Fi Version | Time is now: 2nd October 2026 - 11:59 PM |
