| jhelgesen |
Dec 18 2009, 09:07 AM
Newbie ![]() Group: Members Posts: 42 Joined: 14-July 08 From: Charlotte Member No.: 9,299 Region Association: None |
Trying to get my barn find 75 1.8l running and working on my FI education.
Looking at the specs on fuel injectors has me confused, L v D jet. From what I'm reading, I can't use D-jet injectors with L-jet system. I currently have a mismatched set of injectors in the car, 3 from a 912e and 1 from the original 1.8. I have a really nice set of yellow 1.7's on the shelf, guess I can't use those....(anyone want to trade?) |
| ClayPerrine |
Dec 18 2009, 11:37 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Trying to get my barn find 75 1.8l running and working on my FI education. Looking at the specs on fuel injectors has me confused, L v D jet. From what I'm reading, I can't use D-jet injectors with L-jet system. I currently have a mismatched set of injectors in the car, 3 from a 912e and 1 from the original 1.8. I have a really nice set of yellow 1.7's on the shelf, guess I can't use those....(anyone want to trade?) The 912E injectors should work fine, but a little richer. But you really need a complete matched set. |
| Drums66 |
Dec 18 2009, 01:53 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
You should be good,but..........like was said try to match them (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif)
| aircooledtechguy |
Dec 18 2009, 04:03 PM
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
D-jet injectors have different electrical connectors than L-jet injectors. I don't think you could swap them if you wanted to unless you spliced the corresponding connectors on the harness. . .
| ClayPerrine |
Dec 19 2009, 04:48 PM
D-jet injectors have different electrical connectors than L-jet injectors. I don't think you could swap them if you wanted to unless you spliced the corresponding connectors on the harness. . . ^They also have different impedance. L-Jet system doesn't have enough voltage at the injector to fire a D-Jet injector. The resistor pack is to lower the voltage at the injector. |
Lo-Fi Version | Time is now: 12th April 2026 - 01:41 PM |
