FS: Moving on Dec 31st! All Parts Must Go!, We are not taking the 914 parts with us! |
914rrr |
Dec 19 2009, 09:06 AM
Senior Member Group: Members Posts: 1,830 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
Moving the end of December.
Below is a list of what we have left. $100 obo best offer plus shipping for the lot!! Caliper Kit (NEW - not sure if front or rear) Odometer reset cable Rain tray funnels w/tubes and seals (pair)- I may have 2 or 3 pairs Turn signal light seals (pair) OEM Window cranks w/mounting washer and bolts (2 pairs – 1 pair has the bezels) Lug bolts (steel wheels) Qty 11 plus 1 oddball Alloy lugs OEM qty 3 Rear trunk latch Air deflector plate - early - drivers side S tubes (pair with clamps) Heater ext tubes (pair) J tubes (pair) 1 is missing top tab Tune Up Parts ( New Distributor cap, oil change gaskets, 2 new condenser points, 2 new points, 4 slightly used spark plugs – W6DC, 1 range colder then stock) Heater levers (1 console and 1 non-console) Door Handles Seals Bolts etc lot Fog light outer bezel with retention springs Metal 2.0 rear badge – 1 short stud 16 OEM Lug caps Door lock tumbler with lever 4 Copper exhaust gaskets 4 New and used shifter bushings Rear trunk release knob and flange (2 sets) Defrost light cover 2 relays Door key Front pan drain tube Pedal pad Pedal stop bracket Plastic dash nuts, and other misc bolts and nuts Heater blower clamp New distributor clamp Shifter base bracket Jack Straps (pair) used Clutch cable pulley, washer, and clutch cable pin/clamp Aftermarket Window Cranks (qty 2) Motormite brand – As good or better then OEM quality – NIP 1 new / 1 used shift rod bushings – transmission end Spare tire plates and brackets (1 early set / 2 late sets / 1 extra plate) Pair New CV Gaskets – Elring brand Transmission speedo drive – used 2.0 Air cleaner base plate and screw assembly with braided cushings that go on intake runners New OEM rear trunk bracket – white plastic |
Al Meredith |
Dec 19 2009, 10:25 AM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Rob, Nel, although I already have at least one of everything on your list, I'll buy them if no one else comes forward. Remember my Cousin lives in Knoxville and my Brother and I were talking about going up to see him on the 28th. I'm sure I can get everything in the back of my SUV. Al
PS: Are you comming to North Georgia like you all talked about 3 months ago??? |
914rrr |
Dec 19 2009, 10:28 AM
Rob, Nel, although I already have at least one of everything on your list, I'll buy them if no one else comes forward. Remember my Cousin lives in Knoxville and my Brother and I were talking about going up to see him on the 28th. I'm sure I can get everything in the back of my SUV. Al PS: Are you comming to North Georgia like you all talked about 3 months ago??? Great! North Georgia plans are dead. The job is taking us to Houston, TX. We were just there the past couple of days, and will probably be more north in The Woodlands, TX. Everything will definitely fit in your SUV. I think Rob has some more items that are included but not on the list. We can hold the items for you if you want. It will be wonderful to see you again! Nel (IMG:style_emoticons/default/santa_smiley.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 10:40 PM |
