Moving the end of December.
Below is a list of what we have left.
$100 obo best offer plus shipping for the lot!!
Caliper Kit (NEW - not sure if front or rear)
Odometer reset cable
Rain tray funnels w/tubes and seals (pair)- I may have 2 or 3 pairs
Turn signal light seals (pair)
OEM Window cranks w/mounting washer and bolts (2 pairs – 1 pair has the bezels)
Lug bolts (steel wheels) Qty 11 plus 1 oddball
Alloy lugs OEM qty 3
Rear trunk latch
Air deflector plate - early - drivers side
S tubes (pair with clamps)
Heater ext tubes (pair)
J tubes (pair) 1 is missing top tab
Tune Up Parts ( New Distributor cap, oil change gaskets, 2 new condenser points, 2 new points, 4 slightly used spark plugs – W6DC, 1 range colder then stock)
Heater levers (1 console and 1 non-console)
Door Handles Seals Bolts etc lot
Fog light outer bezel with retention springs
Metal 2.0 rear badge – 1 short stud
16 OEM Lug caps
Door lock tumbler with lever
4 Copper exhaust gaskets
4 New and used shifter bushings
Rear trunk release knob and flange (2 sets)
Defrost light cover
2 relays
Door key
Front pan drain tube
Pedal pad
Pedal stop bracket
Plastic dash nuts, and other misc bolts and nuts
Heater blower clamp
New distributor clamp
Shifter base bracket
Jack Straps (pair) used
Clutch cable pulley, washer, and clutch cable pin/clamp
Aftermarket Window Cranks (qty 2) Motormite brand – As good or better then OEM quality – NIP
1 new / 1 used shift rod bushings – transmission end
Spare tire plates and brackets (1 early set / 2 late sets / 1 extra plate)
Pair New CV Gaskets – Elring brand
Transmission speedo drive – used
2.0 Air cleaner base plate and screw assembly with braided cushings that go on intake runners
New OEM rear trunk bracket – white plastic
