| kconway |
Dec 19 2009, 09:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
What size is the nut that secures the steering wheel? Gotta take it off to change out my dash frame.
Kev |
| jaxdream |
Dec 19 2009, 09:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
27 mm .
Jaxdream |
| jaxdream |
Dec 19 2009, 09:27 PM
If you are removing the frame , just unbolt the whole steering column , 4 allen head / hex 8mm socket / 13mm hex ( which ever you have ). You would probably plan on removing the column anyway.
Jaxdream |
| smg914 |
Dec 20 2009, 03:27 PM
Sahara Beige Steve ![]() ![]() ![]() Group: Members Posts: 1,988 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
I believe a 1 1/16 standard will work too.
| maf914 |
Dec 22 2009, 03:21 PM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
I believe a 1 1/16 standard will work too. Yep, I used a 1-1/16" because I had one from my Dad's old tool collection. 1-1/16" = 26.9875 mm, which is pretty close! (IMG:style_emoticons/default/laugh.gif) |
| Todd Enlund |
Dec 22 2009, 03:24 PM
Resident Photoshop Guru ![]() ![]() ![]() ![]() Group: Members Posts: 3,252 Joined: 24-August 07 From: Reed (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
An impact wrench makes it easy, otherwise you'll need to figure out how to hold the steering wheel to get leverage on it.
| kconway |
Dec 22 2009, 05:23 PM
I picked up a $8 27mm socket and used an impact wrench, 5 seconds later; viola!
Lo-Fi Version | Time is now: 26th June 2026 - 11:20 PM |
