Full Version: What Size Is This Nut?
kconway
What size is the nut that secures the steering wheel? Gotta take it off to change out my dash frame.
Kev
jaxdream
27 mm .
Jaxdream
jaxdream
If you are removing the frame , just unbolt the whole steering column , 4 allen head / hex 8mm socket / 13mm hex ( which ever you have ). You would probably plan on removing the column anyway.
Jaxdream
smg914
I believe a 1 1/16 standard will work too.
maf914
QUOTE(smg914 @ Dec 20 2009, 01:27 PM) *
Yep, I used a 1-1/16" because I had one from my Dad's old tool collection.
1-1/16" = 26.9875 mm, which is pretty close! laugh.gif
Todd Enlund
An impact wrench makes it easy, otherwise you'll need to figure out how to hold the steering wheel to get leverage on it.
kconway
I picked up a $8 27mm socket and used an impact wrench, 5 seconds later; viola!
