Dominic |
Dominic ![]() ![]() ![]() Group: Members Posts: 993 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California ![]() |
I would love to see the dyno results on this 4-16 BHP gain (IMG:style_emoticons/default/bs.gif)
Maybe he offers free CNC head porting with those battery ground cables (IMG:style_emoticons/default/confused24.gif) Free headers (IMG:style_emoticons/default/confused24.gif) I have been searching for an extra 16 BHP for quite some time and I can't believe it was hiding this whole damn time in my stock battery cables??? (IMG:style_emoticons/default/WTF.gif) http://cgi.ebay.com/ebaymotors/BATTERY-UBE...=item2c5240be04 BATTERY UBERGROUND MOST PORSCHE 911 912 '68-88 MODELS 4-16 BHP gain + Overall Improvements US Made UL Approved 1 KabelMann Uberground Negative cable KM0012 - 12inches overall length Fitment for: Porsche 911 '64-'88 924/944 '77-'96 BMW 316 318i 320i 323 325 328 330 e i is, 520 523 525 528 530 535 540 e i is, M3 M5 M6 model BMW's early and late Mercedes Benz: 190E 260E 300E 500E E320 E420 E430 E500 C220 C230 C280 C320 C36 C43 *Based on above car manufacturer specs this will fit the listed cars HOWEVER, Please measure your stock battery-ground wire Measure your stock battery-ground wire end to end if unsure Fully made In USA 2-ott/Double-Zero Gauge, 12mm thick fine-strand 99.9 pure copper wire Heavy Butyl Rubber casing with anti-moisture inner layer Tin-coated thick-wall copper terminals, corrosion resistant. Triple hex-crimped [at each end= 36 maximum contact areas Weather-protected heat-shrink wrapped connections BIG 2-ott/double-zero [-2x gauge] fine-strand 99.9 pure copper vs typical stock grounds: 4 or 2-gauge blended-alloy wire 4-16HP gain due to less Alternator load and increased ignition spark energy greatly lowered circuits resistance Noticeable overall improvement of electrical functions, driveability, roadworthiness Our KabelMan Uberground works on basic principle Each powered circuit/part has its own [+] supply line from batt thru switching; yet all flowing circuits return through the batt [-] pole/side via 1 lone wire/line which tends to get coagulated w/ electrical noise and resistance. By eliminating almost all the 'traffic' getting back around through the main ground cable better conductivity and efficiency is achieved BHP gains are by less work for alternator, better spark signal from minimal resistance, 'noise'. Increased conductivity= much lowered resistance through vehicle electrical circuits provides less alternator load, more ignition spark energy Alternators consume up to 24 HP while engine running Starter cranks stronger; better starting moments Extended life of alternator, battery, starter, coils, relays, control/computer boxes, other components Wipers, power windows, lighting, stereo radio, etc. work better especially on older classic vehicles Great upgrade to old or new BMW Porsche Mercedes electrical systems |
zymurgist |
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None ![]() |
Looks like a pretty decent cable, but why do they have to make wildly optimistic claims about HP? I can't imagine that anyone who owns these old cars would fall for it... either they work on their own car and can see through BS like this, or they have a trusted wrench who will tell them that these claims are bogus.
blitZ |
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States ![]() |
I wonder if the concept is your old ground cable is going bad and you could be losing hp? Either way, I could make my own ground with marine grade cable for less than $40
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
There is some benefit to having clean grounds from engine to chassis.
However Flat copper braid that is hot tin dipped from each cylinder head to chassis is the right way to do it. The ground strap to the chassis and transaxle is OK but not electically great. |
goodwood73 |
Wherever you go, There you are. ![]() Group: Members Posts: 40 Joined: 3-July 05 From: Woodstock, GA Member No.: 4,368 ![]() |
Two of these a k&n filter and some Zmax and you can double the horsepower in a stock 1.7. (IMG:style_emoticons/default/drunk.gif)
whatabout1 |
Toys in Red ![]() ![]() Group: Members Posts: 403 Joined: 6-March 06 From: Charlotte, NC Member No.: 5,676 Region Association: None ![]() |
Oh, I thought he was talking about starter motor HP gain vs. no ground at all. (IMG:style_emoticons/default/lol-2.gif)
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
ignition spark energy greatly lowered circuits resistance Noticeable overall improvement of electrical functions, driveability, roadworthiness I can see some HP gain...with weak connections the alternator certainly will produce a larger load....not sure if it would be as much as claimed...but that is the beauty of advertising...prove him wrong. Rich |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE all flowing circuits return through the batt [-] pole/side via 1 lone wire/line which tends to get coagulated w/ electrical noise and resistance. So THAT'S been my problem all along ! Noise coagulation! I know it's an old racer's trick to open the alternator field wire during qualifying or other "all out" effort - but I don't think anybody ever claimed 16HP from _completely_ eliminating alternator load. _1_ HP is ~750W. You got a 1000A alternator? I don't... |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,815 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
What if you bought two cable? Would you get double?
zymurgist |
craig3x |
Member ![]() ![]() Group: Members Posts: 106 Joined: 18-April 09 From: Sacramento Member No.: 10,275 Region Association: None ![]() |
it can do it cuz it's an "uber" ground cable. (IMG:style_emoticons/default/lol-2.gif)
Cheapsnake |
Member ![]() ![]() Group: Members Posts: 419 Joined: 15-November 07 From: Door County, WI Member No.: 8,341 ![]() |
Damn! that would go great with my patented high speed, low friction muffler bearings!
rascobo |
Member ![]() ![]() Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest ![]() |
Few people have ever lost money playing to the ego of a Porsche Owner.
(The loving, adoptive parents of bastard born, half breed 914 Porsche/Volkswagons are of course excluded from such blatant generalizations) |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Another thread on this went around earlier, in case you want to get in on more entertainment.
rascobo |
I just had to check-out his other items listings and I shit you not....
'Hi Performance Racing Lug Nuts' I can almost hear His pitch now...... Our patented Hi Tech Hi Performance Racing Lug Nuts are Guaranteed to at least double Your cars speed and performance compared to an otherwise identically prepared model without any *. (*) Fairness dictates We admit the cars running without any do tend stop quicker. (IMG:style_emoticons/default/new_shocked.gif) |
Lo-Fi Version | Time is now: 30th July 2025 - 10:55 PM |
