FS Almost all parts from 1970 914. Some free |
70_914 |
Dec 22 2009, 03:55 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
I just picked up a 1973 (I think) 1.8 (I think) that has good paint and floor pans, complete body with bumpers. It is in nicer shape than my 1970 from an appearance standpoint. The 1970 is now on the market for everything except for calipers and... that is probably all. Drivers door is not in good shape, passenger door is fine. Door glass good in both doors, windshield is cracked, rear window good. Hood, trunk lid, engine cover all in good shape. Taillights OK. Dash is rusty and in poor shape but the heater controls are good. Blower motors OK, headlight motors work, headlight doors and eyebrows in good shape. Wiper motor and linkage are out and in good shape. Gauges have the aluminum surround and I might put that in the other car... I will have a better Idea when I get my new one home and look at it....
1970 914: Pretty much everything will be going for less than $50 + shipping, large things like doors would appreciate local pickup only. Thanks for looking, I can post pictures of specific parts as needed. If you want a large # of parts just take the whole car (I want the engine for my new car) $200. Kevin k_mesaros@yahoo.com 253-227-3085 Car is in Roy, WA. |
Eric_Shea |
Dec 22 2009, 08:07 PM
I'll take the steering wheel.
Markl |
Dec 23 2009, 12:48 AM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
Hi, I don't know much about carb setups - do these have chokes? Are they adequate for a stock 2.0 liter? Thanks
wayne1234 |
Dec 23 2009, 01:38 AM
Member Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None |
I would like to get at least the center case bolt. or the set(if you have them all) if you dont wanna separate. let me know and $ I guess a bubble pack envelope would shipp fine 46158 Thanks
wayne1234 |
Dec 23 2009, 01:40 AM
Actually if you ahve the mounting bolts to the front of engine that mount the brackets below the oil pump that would be great also.
70_914 |
Dec 23 2009, 10:43 AM
70_914 |
Dec 23 2009, 10:46 AM
I would like to get at least the center case bolt. or the set(if you have them all) if you dont wanna separate. let me know and $ I guess a bubble pack envelope would shipp fine 46158 Thanks Center case bolt?? There are a butt load of bolts. Are you talking just the bolts and not the studs and nuts? Center top, front, back, bottom? I have no problem selling bolts from the engines but 1 did break on the 1.7 and I have not taken the 2.0 apart yet, and I want to be sure that we are talking about the same bolts. I will also check the mounting bolts near the oil pump. Now that I know what people are interested in I will make a better effort to send pictures. Thanks |
wayne1234 |
Dec 23 2009, 01:35 PM
yeah there is a case bolt that goes on the passenger side under the push rod tubes it does not have a nut, it threads into the other case half.... if you have a set that has one broken as long as it isnt that one that is cool, mine is a 2.0 are the case bolts different? I need it for a 2.0 Thanks...
70_914 |
Dec 24 2009, 08:55 PM
I took off the steering wheel cover and it is leather underneath- the top of it is worn through from 30+ years of driving, the seams are split.
(IMG:http://img.photobucket.com/albums/v260/k_mesaros/Car/DSCF1652.jpg) Here are the carburetors removed from the car. You can see the velocity stacks clearly. (IMG:http://img.photobucket.com/albums/v260/k_mesaros/Car/DSCF1653.jpg) (IMG:http://img.photobucket.com/albums/v260/k_mesaros/Car/DSCF1654.jpg) |
70_914 |
Dec 24 2009, 09:00 PM
Here is 1 of the carbs installed on the car, with an old filter. They come with the linkage and intakes, air cleaner tops and bases, 2 new and unopened K&N filters. If the strange throttle cable bracket is needed it goes too.
(IMG:http://img.photobucket.com/albums/v260/k_mesaros/Car/DSCF0942.jpg) |
70_914 |
Dec 24 2009, 09:08 PM
Not the best picture, but I think it works.
(IMG:http://img.photobucket.com/albums/v260/k_mesaros/Car/DSCF0940.jpg) Explains itself... (IMG:http://img.photobucket.com/albums/v260/k_mesaros/Car/DSCF0944.jpg) |
Als914 |
Dec 26 2009, 12:55 PM
Lighting my way Group: Members Posts: 330 Joined: 1-January 06 From: Hemet,Ca. Member No.: 5,346 Region Association: Southern California |
Hey Kevin,
How much for the gauge cluster and face plate pictured? Al |
914coop |
Dec 30 2009, 11:15 AM
Member Group: Members Posts: 214 Joined: 5-September 08 From: Minneapolis Member No.: 9,514 Region Association: Northstar Region |
Carbs still available?
70_914 |
Dec 30 2009, 05:52 PM
Hey Kevin, How much for the gauge cluster and face plate pictured? Al The gauge cluster picture is actually a picture of the steering wheel, which is already sold pending me getting off my @$$ and shipping it out... I am not parting my car, I am selling stock "junk" that I am not going to use. |
70_914 |
Dec 30 2009, 05:53 PM
Carbs still available? Yep. Carbs are still available. Only thing spoken for so far is the steering wheel. You know you want these... They are all nice and clean. These things practically sell themselves.... Seriously though, they are in decent shape and still have the tags on them. |
70_914 |
Dec 30 2009, 05:54 PM
I would like to get at least the center case bolt. or the set(if you have them all) if you dont wanna separate. let me know and $ I guess a bubble pack envelope would shipp fine 46158 Thanks Center case bolt?? There are a butt load of bolts. Are you talking just the bolts and not the studs and nuts? Center top, front, back, bottom? I have no problem selling bolts from the engines but 1 did break on the 1.7 and I have not taken the 2.0 apart yet, and I want to be sure that we are talking about the same bolts. I will also check the mounting bolts near the oil pump. Now that I know what people are interested in I will make a better effort to send pictures. Thanks The case bolt you are looking for is the unfortunate one that broke on my 1.7. When I get the 2.0 apart I will be more careful.... I will let you know how it works. |
914coop |
Dec 30 2009, 06:19 PM
How long have they been Sitting, also can you take a picture of where they mount to the heads? need to verify they will bolt up to the 2..0 heads.
70_914 |
Dec 30 2009, 07:05 PM
How long have they been Sitting, also can you take a picture of where they mount to the heads? need to verify they will bolt up to the 2..0 heads. Carbs still available? Yep. Carbs are still available. Only thing spoken for so far is the steering wheel. You know you want these... They are all nice and clean. These things practically sell themselves.... Seriously though, they are in decent shape and still have the tags on them. They have been sitting since my first post - 1 week, and I drove it to where I am working on it. Before that they were mounted to the car- I have owned it about 4 months. How long the car sat in the junk yard- 3 days. Before that- ??? This car is a 1970 1.7. I have an extra engine apart, so if you want I can take pictures of the manifold mocked up on one of those heads, or was there something different and more specific you were looking for? On a quick side note - who would use this emoticon for any real reason - (IMG:style_emoticons/default/sheeplove.gif) |
914coop |
Dec 30 2009, 08:03 PM
The 2.0 heads have a 3 bolt pattern to attach the manifold to the heads the others gave a four bolt pattern.
Just making dure when you said they worked fine on the car you has they have not been sitting long enough yo need to be rebuikt. How long have they been Sitting, also can you take a picture of where they mount to the heads? need to verify they will bolt up to the 2..0 heads. Carbs still available? Yep. Carbs are still available. Only thing spoken for so far is the steering wheel. You know you want these... They are all nice and clean. These things practically sell themselves.... Seriously though, they are in decent shape and still have the tags on them. They have been sitting since my first post - 1 week, and I drove it to where I am working on it. Before that they were mounted to the car- I have owned it about 4 months. How long the car sat in the junk yard- 3 days. Before that- ??? This car is a 1970 1.7. I have an extra engine apart, so if you want I can take pictures of the manifold mocked up on one of those heads, or was there something different and more specific you were looking for? On a quick side note - who would use this emoticon for any real reason - (IMG:style_emoticons/default/sheeplove.gif) |
Smitty911 |
Dec 31 2009, 12:37 AM
Member Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California |
I have a complete 1.7 engine that I have taken apart and only need the case from. No injection parts on it, didn't pay much so I don't want much. Let me know what you need. Kevin k_mesaros@yahoo.com 253-227-3085 Local pickup preferred. I work in Aburn, WA and live in Roy, WA. Rocker Arms off the 1.7????? Avalible??? how much? |
Lo-Fi Version | Time is now: 17th May 2024 - 04:49 AM |
