FS Gauging interest. 2.0L FI, heads, 19 MM front sway bar, Rear Koni gas shocks, SS trans with broken ears |
bdstone914 |
Dec 26 2009, 09:06 AM
I have picked up an engine, trans, front and rear suspension from a 914 that was put nose first into a ditch. The engine has 2.0L FI and heads and is an EC case. The valve cover has "Hydro Cam" painted so it may be a bus short block with 2.0L top end. It has an aftermarket 19 mm front sway bar with aluminum shackles and adjustable drop links with Heim joints. The shackles appear to be homemade. On of the bolts is stripped out in the housing. It will need to have a through bolt put in like the other shackle. The cone shaped retainers and bushings are missing but I have new ones on order.
Rear suspension has late Koni OIL filled shocks. I first thought they were gas filled. The SS trans has the ears snapped off from the nose dive into the ditch. The broken ears are there and could be welded back on. If the parts check out OK here are the asking prices. Sway bar with hardware Rear Koni shocks $ 2.0L FI $200 2.0L heads $300 SS trans $125 Will post pictures as I get the parts checked out. (IMG:http://img683.imageshack.us/img683/8228/dscf0007r.th.jpg) (IMG:http://img13.imageshack.us/img13/769/dscf0008lg.th.jpg) (IMG:http://img259.imageshack.us/img259/583/dscf0006.th.jpg) Bruce |
yeahmag |
Dec 26 2009, 10:03 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Bruce,
I may be interested in the shocks if you can get me some pictures. Leamon thinks my passenger side rear shock may be blown. -Aaron |
bdstone914 |
Dec 26 2009, 10:12 AM
Bruce, I may be interested in the shocks if you can get me some pictures. Leamon thinks my passenger side rear shock may be blown. -Aaron Hi Aaron, Do not toss that blown shock. I found a place that can rebuild them. Do you have the gas filled late style or the early ones that are oil filled. The late ones have the triangular logo at the bottom and the early ones have the logo that looks like the flying wing and are marked "Special D" I have a second pair of gas filled and other oil filled shocks too. Bruce |
jcb29 |
Jul 22 2010, 07:02 PM
Member Group: Members Posts: 89 Joined: 29-August 04 From: Clovis, CA Member No.: 2,646 Region Association: Central California |
Bruce - your "rebuild" place - do they just work on customers sets sent in or do they have a "core" program?
Lo-Fi Version | Time is now: 16th May 2024 - 05:06 AM |
