I have picked up an engine, trans, front and rear suspension from a 914 that was put nose first into a ditch. The engine has 2.0L FI and heads and is an EC case. The valve cover has "Hydro Cam" painted so it may be a bus short block with 2.0L top end. It has an aftermarket 19 mm front sway bar with aluminum shackles and adjustable drop links with Heim joints. The shackles appear to be homemade. On of the bolts is stripped out in the housing. It will need to have a through bolt put in like the other shackle. The cone shaped retainers and bushings are missing but I have new ones on order.
Rear suspension has late Koni OIL filled shocks. I first thought they were gas filled. The SS trans has the ears snapped off from the nose dive into the ditch. The broken ears are there and could be welded back on.
If the parts check out OK here are the asking prices.
Sway bar with hardware
$200 $175
Rear Koni shocks $
125 $100
2.0L FI $200
2.0L heads $300
SS trans $125
Will post pictures as I get the parts checked out.
Bruce
