Any tricks to getting a header collector on? |
jgara962 |
Dec 26 2009, 12:55 PM
Yo, this is how I roll Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
Does anyone have tips or tricks to getting the merge collector to slide on? All the pipes are still loose and easily manuverable, but I'm having a hard time getting the collector on. I can get the two bottom pipes to slide on about an inch before things start to bind up. Right now I have the two bottom and one top pipe in and the final pipe just barely in, but it won't seem to budge any further. I'm still several inches away from two tabs lining up that get a bolt in them to hold the whole thing together.
ChrisFoley |
Dec 26 2009, 01:29 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Did you leave the exhaust port connections loose?
They shouldn't be tightened until the collector is in place. |
jgara962 |
Dec 26 2009, 01:40 PM
jgara962 |
Dec 27 2009, 11:14 AM
Can I spray a littlt WD40 down the collector to lube things up? Will it just burn off or catch fire?
ChrisFoley |
Dec 27 2009, 12:54 PM
Can I spray a littlt WD40 down the collector to lube things up? Will it just burn off or catch fire? I typically use Never-Seez. It will smoke when the header heats up but helps get it back apart if needed. Milk of Magnesia is better for long-term anti-seize. When a header is H/T coated the joints are more susceptible to galling and anti-seize is even more important. |
Lo-Fi Version | Time is now: 13th May 2024 - 10:33 PM |
