QUOTE(jgara962 @ Dec 27 2009, 12:14 PM)
Can I spray a littlt WD40 down the collector to lube things up? Will it just burn off or catch fire?
I typically use Never-Seez. It will smoke when the header heats up but helps get it back apart if needed. Milk of Magnesia is better for long-term anti-seize.
When a header is H/T coated the joints are more susceptible to galling and anti-seize is even more important.
