Oil Screen for, Tuna can |
tradisrad |
Dec 29 2009, 09:41 AM
I got a tuna can for Christmas and I am eager to install it, however I don't see how I can use the oil screen with it.
My friend just pulled some metal pieces off of his oil screen and this was enough to convince me that I should be running the oil screen with the tuna can. Has any one come up with a solution to use a screen with the tuna can? |
ws91420 |
Dec 29 2009, 09:44 AM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
As far as I know you can't run a screen with a tuna can.
detoxcowboy |
Dec 29 2009, 10:01 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
tuna can = no oil screen (says so in the directions though some places try to sell you one with it)
VaccaRabite |
Dec 29 2009, 12:55 PM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The screen doe not really do anything for you anyway, and all of your oil is going through a filter. if whatever is in your case is big enough to be blocked by the oil screen, you have other problems.
Zach |
stownsen914 |
Dec 29 2009, 03:54 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Actually it can be done, but you have to make it. I felt a little funny putting on the tuna can years ago on my 914 without some type of screen, so I made one. That car is long gone so no pics and only rough memory of how I did it, but you need to be careful not to restrict oil flow. I have some memory that in modifying my screen to work with the tuna can, I had to block off some openings on the side of the screen and open up some holes in the flat aluminum base. Sorry no pics ... I did that mod many moons ago.
Scott |
tradisrad |
Dec 29 2009, 04:20 PM
The screen doe not really do anything for you anyway, and all of your oil is going through a filter. if whatever is in your case is big enough to be blocked by the oil screen, you have other problems. Zach My friend pulled his screen out the other day and he had some big pieces of metal on his screen. I am sure he has/is developing other problems. If he did not have the screen he would have had metal pieces going into his oil pump and passages. My engine is much fresher than his and at this point I probably don't need the screen, but the added protection and peace of mind never hurts. -Rob |
Lo-Fi Version | Time is now: 15th May 2024 - 09:09 AM |
