Shift Rod adjustment |
luvatenor |
Dec 30 2009, 03:18 AM
Newbie Group: Members Posts: 47 Joined: 20-December 09 From: NY Member No.: 11,154 Region Association: None |
Having replaced all of the shift rod bushings in my 76'(what a difference, and I actually enjoyed the experience), I now undertake the final adjustment. 1st and Reverse snap in, 2nd and 3rd are good but 4th and 5th are vague. I remember that the shift rod has to be rotated one spline at a time until it is correct. Is it clockwise or counter clockwise? As always, thank you-Rolf
AvalonFal |
Dec 30 2009, 10:56 AM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Having replaced all of the shift rod bushings in my 76'(what a difference, and I actually enjoyed the experience), I now undertake the final adjustment. 1st and Reverse snap in, 2nd and 3rd are good but 4th and 5th are vague. I remember that the shift rod has to be rotated one spline at a time until it is correct. Is it clockwise or counter clockwise? As always, thank you-Rolf I believe rotating clockwise makes 4th & 5th easier, but Rev and 1st more difficult. Paul |
etcmss |
Dec 31 2009, 05:53 AM
etcmss Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest |
did you get this solved?
I didn't think the spline adjustment you describe makes any difference. The one I was thinking about (in the center tunnel at the shifter) doesn't fit by splines --its a slip fit over the splines (unless I'm off track here) If its the one at the shifter I had this problem where 4th and 5th were not clean-the shifter alignment was off and the bolts got in the way-even though it worked. |
luvatenor |
Dec 31 2009, 05:59 AM
did you get this solved? I didn't think the spline adjustment you describe makes any difference. The one I was thinking about (in the center tunnel at the shifter) doesn't fit by splines --its a slip fit over the splines (unless I'm off track here) If its the one at the shifter I had this problem where 4th and 5th were not clean-the shifter alignment was off and the bolts got in the way-even though it worked. Yes I think I finally understand the procedure. I put a vice grip on the shift rod in the tunnel, loosened the pinch bolt alot and moved the shifter a little clockwise and re-tigthened the pinch bolt. 4th and 5th are now there. A few more adjustments and all of the gears are accessible with definite 'gate' feel. It took me awhile(getting old) but felt great .Hope that helps-Rolf |
EdwardBlume |
Dec 31 2009, 02:15 PM
Adjustment can be tricky, but the more time you spend on it.. eventuall you figure it out.
I installed a rennshifter on my race car with the updated positive linkage back to the case, and it was.. um interesting to say the least. |
detoxcowboy |
Jan 1 2010, 09:59 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Shifter/Shift Rod Indexing.. Lean the Shifter towards the 1st/2nd before and holding that position while tightening the Shift Rod Connector Bolt this enable an smoother/looser 4th/5th ...lean the Shift Rob the other way towards 4th/5th leaves an easier/smoother 1st/2nd .. to far either way has the opposite effect the other side so in extreme you could smooth as honey 1st while just about if not completely difficult 4th/5th.. So you have to play with a bit,. I found leaning/pushing just a bit 10mm or so towards and into the reverse springed bar/guide/protection and holding there while tightening is a pretty close point to start.. (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 13th May 2024 - 07:06 PM |
