2.0 to 1.7 conversion, case convversion |
NOSLIWW |
Jan 1 2010, 12:56 PM
Newbie Group: Members Posts: 3 Joined: 18-September 08 From: Mississippi Member No.: 9,562 Region Association: None |
My 2.0 blew a 6" hole in the top of the crankcase, both halfs. Can you tell me if (of course if they're not damaged) I can use all the components in a 1.7 case?
Point me in the direction of good reference material for re-build? Appreciate your comments/guidance... Bill |
underthetire |
Jan 1 2010, 01:00 PM
I think the 1.7 is the case used to make the big motors, so yes you can use it. Machine work will be required. Type 4 store has a DVD on building them, I havn't seen it myself.
GeorgeRud |
Jan 1 2010, 03:39 PM
Contact Jake Raby? I think the cases are the same exept for machine work. The internal components, pistons and cylinders, and heads are all different.
sww914 |
Jan 1 2010, 04:03 PM
Either case will work if you're not concerned about the numbers. Everything else inside is different except fr some of the bearings, seals and probably the lifters & pushrods.
Here's a decent book http://www.amazon.com/Rebuild-Volkswagen-a...3279&sr=1-9 |
McMark |
Jan 1 2010, 04:12 PM
Cases are the same, except some very early 1.7s. Internals are different. Your crank and a rod or two are likely scrap.
Lo-Fi Version | Time is now: 14th May 2024 - 12:55 AM |
