NOSLIWW
Jan 1 2010, 12:56 PM
My 2.0 blew a 6" hole in the top of the crankcase, both halfs. Can you tell me if (of course if they're not damaged) I can use all the components in a 1.7 case?
Point me in the direction of good reference material for re-build?
Appreciate your comments/guidance...
Bill
underthetire
Jan 1 2010, 01:00 PM
I think the 1.7 is the case used to make the big motors, so yes you can use it. Machine work will be required. Type 4 store has a DVD on building them, I havn't seen it myself.
GeorgeRud
Jan 1 2010, 03:39 PM
Contact Jake Raby? I think the cases are the same exept for machine work. The internal components, pistons and cylinders, and heads are all different.
sww914
Jan 1 2010, 04:03 PM
Either case will work if you're not concerned about the numbers. Everything else inside is different except fr some of the bearings, seals and probably the lifters & pushrods.
Here's a decent book
http://www.amazon.com/Rebuild-Volkswagen-a...3279&sr=1-9
McMark
Jan 1 2010, 04:12 PM
Cases are the same, except some very early 1.7s. Internals are different. Your crank and a rod or two are likely scrap.
