interesting part on eBay ..., from AA |
Gustl |
Jan 3 2010, 01:21 PM
914 enthusiast & historian Group: Members Posts: 11,503 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
browsing eBay, I just found a "pretty rare part" - offered from AA
Porsche 914 factory original 4 speed shift knob new NOS (IMG:style_emoticons/default/av-943.gif) |
pillay2k |
Jan 3 2010, 01:25 PM
Member Group: Members Posts: 74 Joined: 21-September 07 From: East Sussex, United Kingdom Member No.: 8,136 Region Association: England |
lol
tod914 |
Jan 3 2010, 01:34 PM
That's used after your 1st gear syncro is shot. Part of the factory HO program.
904svo |
Jan 3 2010, 01:44 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
It for a 911 or 912 . Look where reverse is.
Mikey914 |
Jan 3 2010, 01:55 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I had seen this after I started production on these, didn't think it was a stock 914, thought it might be a more rare trans. But, 912 makes sense, I thought they were 5 spd.
And just a heads up. Porsche is starting to make the 914 shifter knobs again, I believe they were $200 and some change. |
Mark Henry |
Jan 3 2010, 02:25 PM
Oh crap (IMG:style_emoticons/default/unsure.gif)
That's not the pattern on a 901 4-speed is it (IMG:style_emoticons/default/huh.gif) I have a 69 901 4-speed that I'm hoping to turn into a 5 with the guts from a 914 box.... (IMG:style_emoticons/default/sad.gif) |
Jan 3 2010, 02:52 PM
Oh crap (IMG:style_emoticons/default/unsure.gif) That's not the pattern on a 901 4-speed is it (IMG:style_emoticons/default/huh.gif) I have a 69 901 4-speed that I'm hoping to turn into a 5 with the guts from a 914 box.... (IMG:style_emoticons/default/sad.gif) What you are proposing is doable, but its easier to start with the right setup. Call Jim at Easy in CA, he has quite a few 901 5 speed trannies on the shelf. A bit closer might be Parker Tyler up in Maine...he may also have a few 5 speeds. Jim will be more reasonable. Rich |
dr914@autoatlanta.com |
Jan 3 2010, 02:54 PM
914 Guru Group: Members Posts: 7,856 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
believe it or not that is for a 911 model 72-86 with a four speed 915 style transmission installed. Too bad because we have at least 50 of them on the shelf brand new!!!!!! Will fit any 65-86 911 912 and 914 and look great only to confuse the 914 thieves as they try to shift into what looks like first and stall the car!!!!!!!!!
browsing eBay, I just found a "pretty rare part" - offered from AA Porsche 914 factory original 4 speed shift knob new NOS (IMG:style_emoticons/default/av-943.gif) |
Mark Henry |
Jan 3 2010, 03:34 PM
Oh crap (IMG:style_emoticons/default/unsure.gif) That's not the pattern on a 901 4-speed is it (IMG:style_emoticons/default/huh.gif) I have a 69 901 4-speed that I'm hoping to turn into a 5 with the guts from a 914 box.... (IMG:style_emoticons/default/sad.gif) What you are proposing is doable, but its easier to start with the right setup. Call Jim at Easy in CA, he has quite a few 901 5 speed trannies on the shelf. A bit closer might be Parker Tyler up in Maine...he may also have a few 5 speeds. Jim will be more reasonable. Rich Why do it the easy way? I like cheap and hard? (IMG:style_emoticons/default/smile.gif) It's for my bug not the 914. |
zymurgist |
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Lo-Fi Version | Time is now: 15th May 2024 - 05:09 AM |
