Little Black Box, By ignition coil |
turnaround89 |
Jan 4 2010, 02:03 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I have recently rewired my car and have power to the ignition coil and starter, the car kicks over, but i have not started it because i have pulled the gas tank. There is a small black box by the ignition coil that connects to the negative side of the coil and is bolted down by one of the ignition coil bracket bolts. What does that do and is it important? The car has electronic ignition and is carb'd. Will my car not start if the black box isn't wired up? Just want to know now, so when it comes time to start my car, ill know what that thing does.
Thanks everybody |
jt914-6 |
Jan 4 2010, 06:30 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
detoxcowboy |
Jan 4 2010, 10:57 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I have recently rewired my car and have power to the ignition coil and starter, the car kicks over, but i have not started it because i have pulled the gas tank. There is a small black box by the ignition coil that connects to the negative side of the coil and is bolted down by one of the ignition coil bracket bolts. What does that do and is it important? The car has electronic ignition and is carb'd. Will my car not start if the black box isn't wired up? Just want to know now, so when it comes time to start my car, ill know what that thing does. Thanks everybody It sounds like it is your electronic ignition.. You will need that. |
tat2dphreak |
Jan 4 2010, 11:05 AM
my " little black box" is a crane ignition. (IMG:style_emoticons/default/smile.gif)
but we'd need to see pics... it could be an electronic coil from all we know right now (IMG:style_emoticons/default/wink.gif) |
jt914-6 |
Jan 4 2010, 11:23 AM
my " little black box" is a crane ignition. (IMG:style_emoticons/default/smile.gif) but we'd need to see pics... it could be an electronic coil from all we know right now (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/agree.gif) |
McMark |
Jan 4 2010, 11:35 AM
ejm |
Jan 4 2010, 11:50 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
with one wire it sounds more like a igntion noise suppression capacitor but pictures would be helpful
turnaround89 |
Jan 4 2010, 11:57 AM
ill try and get some pictures of it today
detoxcowboy |
Jan 4 2010, 01:30 PM
Lo-Fi Version | Time is now: 14th May 2024 - 06:44 PM |
