Replaced Training Arm Bushings to Poly-Bronze, (sorry, no pics) |
ericread |
Jan 5 2010, 07:10 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
This past weekend I replaced my original rear rubber trailing arm bushings with Elephant Poly-Bronze bushings.
Well, technically, I replaced the left trailing arm rubber bushing and installed the right side bushing, because the right side rubber bushing was completely shot. I had noticed when I put my car up on jackstands earlier in the week that the right trailing arm actually had about an inch of play left to right. Although I knew that I needed to replace my rear wheel bearing, I wasn't aware (until then) that the trailing arm bushings were also completely shot. The folks at Elephant sent me a set of trailing arm bushings and I got to work the morning of January 2. I carefully followed the instructions for rebuilding the trailing arms (located in this BBS) and 20 hours later, I drove off with new bushings and a new left wheel bearing. Luckily, there was no elongation of the bushing mounting holes. Why did it take me 20 hours??? There was a lot of trial and error in replacing the brake correctly. Additionally, since I don't have a press I could use to remove the old bushing rods out, I had to drill-out the remaining rubber, which was somewhat time consuming (and a real PIA). But I told you that story to tell you this: The new poly-bronze bushings have made a huge improvement in making the car feel less stiff, while providing greater driving accuracy. I had previously upgraded to poly-bronze on the front suspension last summer. Now, having the new bushings on all four suspension corners allows the springs, struts, shocks and torsion bars to work more efficiently. This provides a smoother ride and better suspension response on rough and curvy roads. If I were to choose between the vibration damping of the old rubber bushings, and the lowered friction of the new poly bronze bushings, I would strongly recommend the new bushings. This is not to say that roller bearings aren't a good option, but my concern with the roller bearings is the higher initial cost and increased amount of maintenance. Whatever you decide to do, please take a few minutes and really check the condition of your existing suspension bushings. Continued driving on severely worn bushings greatly reduces your ability to control your vehicle. Eric |
Lo-Fi Version | Time is now: 28th May 2024 - 11:52 PM |
