Sealants, Curil products |
jeffdon |
Jan 7 2010, 03:28 PM
got the following, where should they go? Do I need anything else?
Curil K2 - Case halves, anywhere else? Curil T Dirko |
StratPlayer |
Jan 7 2010, 03:38 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Curil T Use between cylinders and engine case, also around the 4 lower head bolt washers.
Dirko Use on your valve cover gaskets. K2 is for you engine case. |
McMark |
Jan 7 2010, 04:44 PM
Loctite 518 on the oil pump.
jeffdon |
Jan 7 2010, 05:40 PM
jeffdon |
Jan 8 2010, 10:53 AM
I seem to recall Jake posting a pretty exhaustive list of sealants and where they are used, but cannot find it now. Can anyone link me to it?
Jake Raby |
Jan 8 2010, 11:18 AM
I seem to recall Jake posting a pretty exhaustive list of sealants and where they are used, but cannot find it now. Can anyone link me to it? Like everything else, sealants continually change and we have to try new things over and over again. The old list was pulled because it was out of date. |
ME733 |
Jan 8 2010, 11:54 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) ...those products listed are not on my favorites list. I use PERMATEX ,(sensor safe) BLUE RTV silicone gasket maker. (part number 6B). available at any local parts store. This sealant can be used everywhere. Out of habit , I use the yellow, windshield sealant on the valve covers, as it holds them solid, does not leak and allows many removals/reinstalls if you grease the outer valve cover gasket,face. The blue permetex will even seal exhaust gaskets.(or replace them if the surfaces are flat.)...It,s complance,heat resistance, and continuing sealing ability with expanding parts,....crankcase, cylinders,(bases), oil pump,etc, etc, IS just superior than anything. (MO). it can be wiped to a thin coat filling the pores of crankcase halves ensuring a tight , torqued, leak proof seal. in my experience nothing is better. it,s PERMATEX blue RTV. (IMG:style_emoticons/default/popcorn[1].gif) Murray
McMark |
Jan 8 2010, 12:15 PM
YES! We get to have the RTV flame storm! (IMG:style_emoticons/default/mueba.gif)
ConeDodger |
Jan 8 2010, 12:19 PM
Apex killer! Group: Members Posts: 23,580 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I SQUIRT BLUE RTV IN YOUR GENERAL DIRECTION!!! |
Lo-Fi Version | Time is now: 10th May 2024 - 12:27 PM |
