914/6 hard line options |
inschool |
Jan 10 2010, 09:07 PM
Newbie Group: Members Posts: 30 Joined: 3-April 09 From: Florida Member No.: 10,229 Region Association: South East States |
I am finishing up a 914/6 conversion, I have a semi stock 6 motor and an OEM tank with 3 oem hoses. I am using the bulkhead mount and am having some fitment issues with the lower oil line. I have an original 914/6 hard line (tank to case). I do not want to hack this line or bend to fit. I tried to have a custom hose made but was unable to find the correct fittings. What line or hose are you conversion guys using? Any members make a hose? |
bcheney |
Jan 10 2010, 09:22 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
I am going to use a flexible line for my conversion. I live in Orlando. Where are you?
GeorgeRud |
Jan 10 2010, 10:27 PM
You can make the line from stainless braided AN-12 or AN-16 oil line. The fittings to convert the AN fittings to the metric Porsche fittings are available from a variety of vendors.
ArtechnikA |
Jan 11 2010, 05:46 AM
Any members make a hose? Elephant has the fittings, as does JB Racing. AN-12 is WAY too small for the hard line. Compare the ID's. The hard line is the delivery line from the tank to the pressure-side pump and can see considerable suction (vacuum). If you are using a braided-steel AN line (e.g. Earls, Aeroquip, Goodridge) you must use an anti-collapse inner spring. SmartRacing has those - probably others too. Elephant is kind of the 'go-to' place for 911 oil systems and Chuck Moreland s a good guy. There are other good places too, don't get me wrong. |
ClayPerrine |
Jan 11 2010, 10:38 AM
Life's been good to me so far..... Group: Admin Posts: 15,454 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There is a Porsche flexible line that is the correct length and size to replace the hardline back to the tank. Contact Rich Johnson (a914guy@aol.com). He can tell you the part number, and even sell you the line.
Lo-Fi Version | Time is now: 12th May 2024 - 01:40 PM |
