QUOTE(inschool @ Jan 10 2010, 10:07 PM)
Any members make a hose?
Elephant has the fittings, as does JB Racing.
AN-12 is WAY too small for the hard line. Compare the ID's.
The hard line is the delivery line from the tank to the pressure-side pump and can see considerable suction (vacuum). If you are using a braided-steel AN line (e.g. Earls, Aeroquip, Goodridge) you must use an anti-collapse inner spring. SmartRacing has those - probably others too.
Elephant is kind of the 'go-to' place for 911 oil systems and Chuck Moreland s a good guy. There are other good places too, don't get me wrong.
