Piston Deck Hieght Range Proper? Copper Gaskets?, Playing with ideas for Compression ratios.. |
detoxcowboy |
Jan 10 2010, 10:30 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
What is the proper deck hieght range for pistons? Mahle 94mmx71mm euro spec.. Curious as to what is perfect and how wide is the safe to error margine? Also what is the take on Copper Gaskets? I understand the professionals sometimes do not use gaskets but I believe I wil be needing some as to keep the comprssion ratio value decent.. My cylider heads measure at 55 cc's on 3 chanbers and 55.1 on 1 chamber (If I am remembering correctly but will have them re cc'd prior) Just trying a layout in my head..
McMark |
Jan 10 2010, 10:59 PM
Copper adds another element of expansion to a critical seal. The logic is that this inequality can cause a leak to form, and a tiny leak will become a huge leak if left long enough in the right conditions. The copper head gasket isn't an assured leak, but leaving it out has proven to be a safe omission.
Spacers under the cylinders is the most frequent method for lowering compression ratio. They are available from the Type 4 Store. |
detoxcowboy |
Jan 10 2010, 11:10 PM
I was thinking same more or less of the copper but had to ask cause I do not know for certain.. does the same theory apply to stamped steel? Seems it would I guess...
Lo-Fi Version | Time is now: 20th May 2024 - 08:15 AM |
