| Larouex |
Jan 11 2010, 10:53 PM
Larouex ![]() ![]() Group: Members Posts: 144 Joined: 22-July 08 From: Larouex@gmail.com Member No.: 9,339 Region Association: Pacific Northwest |
Hello,
I have searched and seen pictures of MSD setups on the 6's, but no pictures of the Crane setup on a 4 CYL... I would appreciate anyone who has installed this system to add a photo (or point me to a thread) so I can see how you installed, what are your impressions and how you fab'd the installation. Cheers, Larouex |
| Grelber |
Jan 12 2010, 07:21 AM
Insert favorite Don Rickles joke here. ![]() ![]() ![]() Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
I made a plate, then painted it. The optical unit and the new coil mount to the plate, then it is mounted to the firewall with nylon standoffs and rubber isolation washers. Here's a picture (that's not rust, it's the glue from the engine bay pad).
Attached thumbnail(s) |
| Larouex |
Jan 12 2010, 10:41 AM
Adding a link to an external install page and info...
http://www.9xauto.com/914ignit.html Link to installed XR700 Ignition in Bosch Dizzy http://cranecams.com/images/downloadable/F...(All%20PNs).jpg Larouex |
| Larouex |
Jan 28 2010, 10:57 PM
Adding pictures of my fab...
(IMG:http://farm5.static.flickr.com/4066/4313218916_d9b60ef4a4.jpg) (IMG:http://farm5.static.flickr.com/4018/4312483119_e49e385bcf.jpg) (IMG:http://farm5.static.flickr.com/4010/4313218726_85f93f3bc6.jpg) (IMG:http://farm3.static.flickr.com/2776/4313218620_fcbdd7fde9.jpg) Cheers, Larouex |
| jaxdream |
Jan 29 2010, 09:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
I see that you are using a ballast resistor , is this required in the setup ??
Jack / Jaxdream |
| detoxcowboy |
Jan 29 2010, 09:35 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
This is my finished set up with the crane "700", for stock 74 2.0. I do not know what your trying to do and have never seen before what you have pictured above so my stock application probably does not concern you but I thought I would throw in for anyone else maybe just wanting to use crane but for a stock application. I mounted the little black box on the fire wall but it could have been hidden w/ a little thought.. simple set up... It has been working perfectly for a couple years w/ a stock distributor and stock bosch blue coil.. 4 cylinder no mods..
| Larouex |
Jan 29 2010, 09:43 AM
| jaxdream |
Jan 29 2010, 09:44 AM
Thanks for the reply !!
Jack / Jaxdream |
| pbanders |
Jan 29 2010, 10:08 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 990 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
I don't have pics right now, but my setup is the XR3000 and the PS60 coil. It's very clean, as the PS60 coil goes right where the OEM coil mounts, and I put the XR3000 on the rear bulkhead, completely out of sight. Very reliable and stable ignition setup.
| detoxcowboy |
Jan 29 2010, 10:12 AM
So your getting a hotter spark with that set up? after you drive on it awhile maybe you could post the real world improvements. I had hot spark stuff for awhile Nology ect.. I sold that crap and never noticed a difference at all, nothing start horse power smother runing ect, in fact after thourogh reading it seemed to cause hard to immeadiatley identify issues in some cases.. but that is not your set up so I am curious to what you notice after your done..
| pbanders |
Jan 29 2010, 10:59 AM
So your getting a hotter spark with that set up? after you drive on it awhile maybe you could post the real world improvements. I had hot spark stuff for awhile Nology ect.. I sold that crap and never noticed a difference at all, nothing start horse power smother runing ect, in fact after thourogh reading it seemed to cause hard to immeadiatley identify issues in some cases.. but that is not your set up so I am curious to what you notice after your done.. Detox, FWIW, I can't say that switching to my XR3000/PS60 setup had any noticable effect on performance over the stock points setup (in good condition and properly set). What I did get was zero maintenance, and a much more stable timing mark, which made setting the timing a bit more accurate. |
| SLITS |
Jan 29 2010, 11:55 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Rather than hotter spark, etc, what it really does is smooth out the idle and acceleration. It does this by eliminating point bounce, maintaining accurate dwell time and eliminating shaft wobble problems in worn dizzys.
While it may produce a hotter spark, you gain little horsepower, but get a cleaner burn in the cylinder (assuming the rest of your system is up to par). Don't expect something for nothing. |
| Grelber |
Jan 29 2010, 12:05 PM
I've had the setup in post #2 for about a year now. I really like it, in that it gives me a clean power range, with no points to adjust. I haven't touched it since it was installed.
I have the 205 disty off of a 1.7L installed on my 2.0L due to the wider curve, and Weber 40's. I'd recommend the system to most anyone. |
| detoxcowboy |
Jan 29 2010, 12:17 PM
So your getting a hotter spark with that set up? after you drive on it awhile maybe you could post the real world improvements. I had hot spark stuff for awhile Nology ect.. I sold that crap and never noticed a difference at all, nothing start horse power smother runing ect, in fact after thourogh reading it seemed to cause hard to immeadiatley identify issues in some cases.. but that is not your set up so I am curious to what you notice after your done.. Detox, FWIW, I can't say that switching to my XR3000/PS60 setup had any noticable effect on performance over the stock points setup (in good condition and properly set). What I did get was zero maintenance, and a much more stable timing mark, which made setting the timing a bit more accurate. True but I am gettng all those benifets that without the ps60 and just the xr700 and stock coil (pictured above).. but maybe there is more to it than just stablity, accuracy, and maintenance. |
Lo-Fi Version | Time is now: 9th June 2026 - 01:23 AM |
