brake reservoir feed lines |
ppeters914 |
Jan 13 2010, 12:11 PM
Newbie Group: Members Posts: 18 Joined: 22-May 07 From: Lake Forest Park, WA Member No.: 7,751 Region Association: Pacific Northwest |
Searched here and Pelican's forums, but nada.
From a 2004 thread: When I looked at the lines feeding from the reservoir to the MC, it looks like someone did a bad "chop job" on them, so I'd like to replace them. Can anyone send pictures, or tell me part numbers, or describe what I need to get? any resource would be helpful. Just to clarify, I want to replace the "low pressure" lines that feed the MC from the brake reservoir. Here are the part numbers. Both listed as NLA everywhere. 914 355 061 00 914 355 063 00 After my initial posting, I contacted Pelican Parts. They CAN get them, but they have to special order them. 3 week turn-around!!!!! egads!!! Any other help? I'm in the same boat. (IMG:http://i97.photobucket.com/albums/l221/ppeters914/914/brakereservoir2Small.jpg) What you don't see is the plastic line cut several inches above the brake m/c feeder tubes. Both Pelican and AutoAtlanta list blue, braided hose. Does this hose replace the plastic and transition hoses, or just the braided transition hose? Or is there another solution? Thanks. Pete '71 1.7L |
dr914@autoatlanta.com |
Jan 13 2010, 12:25 PM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
there are plastic lines attached to the blue short cloth connecting lines. Still available under a superseded part number. We order from Porsche about 50 each.
Searched here and Pelican's forums, but nada. From a 2004 thread: When I looked at the lines feeding from the reservoir to the MC, it looks like someone did a bad "chop job" on them, so I'd like to replace them. Can anyone send pictures, or tell me part numbers, or describe what I need to get? any resource would be helpful. Just to clarify, I want to replace the "low pressure" lines that feed the MC from the brake reservoir. Here are the part numbers. Both listed as NLA everywhere. 914 355 061 00 914 355 063 00 After my initial posting, I contacted Pelican Parts. They CAN get them, but they have to special order them. 3 week turn-around!!!!! egads!!! Any other help? I'm in the same boat. (IMG:http://i97.photobucket.com/albums/l221/ppeters914/914/brakereservoir2Small.jpg) What you don't see is the plastic line cut several inches above the brake m/c feeder tubes. Both Pelican and AutoAtlanta list blue, braided hose. Does this hose replace the plastic and transition hoses, or just the braided transition hose? Or is there another solution? Thanks. Pete '71 1.7L |
Jan 13 2010, 12:26 PM
also plenty of used sets available
underthetire |
Jan 13 2010, 12:38 PM
Can't you just buy metric plastic line from McMastercarr, if the plastic is what you are looking for.
http://www.mcmaster.com/#tubing/=5cy4tq |
ClayPerrine |
Jan 13 2010, 01:23 PM
Can't you just buy metric plastic line from McMastercarr, if the plastic is what you are looking for. http://www.mcmaster.com/#tubing/=5cy4tq Is it brake fluid resistant? |
Katmanken |
Jan 13 2010, 01:27 PM
Better have skills with plastics tubing bending if you are doing your own.....
Did I mention the metal tubing inserts in the bottom ends of the tubing? That's what rusted and leaked in my car... |
Jan 13 2010, 01:42 PM
Better have skills with plastics tubing bending if you are doing your own..... Did I mention the metal tubing inserts in the bottom ends of the tubing? That's what rusted and leaked in my car... yup factory pieces are preformed with the metal in them that is why they are expensive. One gets what they pay for. (most of the time from Porsche! Their front factory hood cable sheaths are the biggest junk ever made. Look like refrigerator ice maker line!) |
underthetire |
Jan 13 2010, 01:58 PM
Can't you just buy metric plastic line from McMastercarr, if the plastic is what you are looking for. http://www.mcmaster.com/#tubing/=5cy4tq Is it brake fluid resistant? Yes. Same material as the reservoir. Didn't know they were pre-formed with metal inserts. I'll have to take a look at mine. Since it is low/no pressure, can you press in the inserts? As far as pre-bending it, don't know. It's not like the stuff is super rigid, and I would think you could wrap the bend around something and hit it with a heat gun. I have some at home I could try with. |
914Sixer |
Jan 13 2010, 03:44 PM
I was thinking about having some made up in SS or steel as replacements for the plastic with the end flared to fit master cylinder. Plastic lines are about $90 EACH. Should be able to have SS's one made for under $75 for the pair.
ppeters914 |
Jan 13 2010, 06:54 PM
Can't you just buy metric plastic line from McMastercarr, if the plastic is what you are looking for. http://www.mcmaster.com/#tubing/=5cy4tq Is it brake fluid resistant? Yes. Same material as the reservoir. Which material? Tygon or....? |
ppeters914 |
Jan 13 2010, 06:56 PM
ppeters914 |
Jan 13 2010, 07:04 PM
(IMG:http://i97.photobucket.com/albums/l221/ppeters914/914/brakereservoir2Small.jpg) What you don't see is the plastic line cut several inches above the brake m/c feeder tubes. Both Pelican and AutoAtlanta list blue, braided hose. Does this hose replace the plastic and transition hoses, or just the braided transition hose? Or is there another solution? Thanks. Pete '71 1.7L there are plastic lines attached to the blue short cloth connecting lines. Still available under a superseded part number. We order from Porsche about 50 each. Also plenty of used sets available. Fifty bucks each? YIKES!!!! (IMG:style_emoticons/default/pinch.gif) I've got a line on a used set. Another option is that there's 3-4 inches of plastic tubing still attached to the metal tubes that fit into the brake m/c. Since I have to replace the upper braided hose anyway, I could do another splice down low. |
6freak |
Jan 14 2010, 09:13 AM
I was thinking about having some made up in SS or steel as replacements for the plastic with the end flared to fit master cylinder. Plastic lines are about $90 EACH. Should be able to have SS's one made for under $75 for the pair. Remember they need to be flexable ...M/C moves when you stomp the brake pedal ......P.S thats a pix of a 911 reservoir |
underthetire |
Jan 14 2010, 09:33 AM
Can't you just buy metric plastic line from McMastercarr, if the plastic is what you are looking for. http://www.mcmaster.com/#tubing/=5cy4tq Is it brake fluid resistant? Yes. Same material as the reservoir. Which material? Tygon or....? I'd probably go with Nylon 11. |
ppeters914 |
Jan 15 2010, 11:35 AM
l ......P.S thats a pix of a 911 reservoir No, that pic is the brake m/c reservoir out of my '71 1.7. Here's a pic before removal: (IMG:http://i97.photobucket.com/albums/l221/ppeters914/914/brakereservoir1Small.jpg) Pete |
6freak |
Jan 15 2010, 11:39 AM
then it has been changed ...stock 4 bangers didnt have an over flow tube
rick 918-S |
Jan 16 2010, 09:56 AM
Hey nice rack! -Celette Group: Members Posts: 20,458 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
6freak |
Jan 16 2010, 01:56 PM
As far as I know ...Only the 6`s had the over flow tube! That came from the 911 system
Slider |
Apr 5 2010, 03:44 PM
Problems are like cockroaches you find 1 and theres a 100 more Group: Members Posts: 223 Joined: 11-March 07 From: Fort Collins Colorado Member No.: 7,591 Region Association: Rocky Mountains |
Hmm thats interesting my 72 1.7 has the overflow tube.
realred914 |
Apr 5 2010, 03:49 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
Lo-Fi Version | Time is now: 16th May 2024 - 02:58 AM |
