Jack points?, best places |
buhs914 |
Jan 16 2010, 09:21 PM
Not So Newbie Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region |
So i know that the lift points are good for jacking but where else is good? I was just wondering because i've heard some debate on a few spots and i need to jack up one wheel for valve adjustment and timing..
P.S. (IMG:style_emoticons/default/ohmy.gif)h and i don't want to put too much pressure on my longs. |
Kirmizi |
Jan 16 2010, 09:50 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
I'd say get yourself some ramps.
At least to be safer. Mike |
McMark |
Jan 17 2010, 12:23 AM
The rear 'donuts' are good places. The front 'donuts' are not. Since you have a late model engine mount, you can use that.
buhs914 |
Jan 17 2010, 01:11 AM
yeah i have ramps and they worked great for my engine drop! so it is ok to use the engine mounting bar then?
Kirmizi |
Jan 17 2010, 02:33 AM
I back mine up on the ramps, then raise one side enough to get a tire free and support the raised side (on the engine bar) with a jack stand. It gives me enough room to slide around beneath the car without worrying about it falling.
Just do a search for "Evil Jackstands" about Gints' close call. Mike |
buhs914 |
Jan 17 2010, 10:31 AM
I back mine up on the ramps, then raise one side enough to get a tire free and support the raised side (on the engine bar) with a jack stand. It gives me enough room to slide around beneath the car without worrying about it falling. Just do a search for "Evil Jackstands" about Gints' close call. Mike Actually i remember reading about that! My jack stands should be fine.. And i actually did the same thing with the ramps. it was already on them from the engine drop so i just jacked up the one wheel and used a jack stand on the engine bar. Thanks for the help though! |
Lo-Fi Version | Time is now: 20th May 2024 - 03:39 PM |
