916 gearbox conversion kit (915 to 914) |
bugat5speed |
Jan 17 2010, 11:16 AM
Member Group: Members Posts: 92 Joined: 1-August 06 From: Germany Member No.: 6,554 |
Hi altogether, still not on our site (www.bugat5speed.de), but ready for market within the 1st quarter of 2010. 916 gearbox conversion parts. Conversion kit is very near to the OE Porsche 916 kit that was offered in small qty. in the 70s. Kit is with the original 916 OE repro sideshift, mechnical components inside and with a very short nosecone (even 5 mm shorter than OE parts 916). Usage of original exhaust systems is no problem. Complete kit for usage with electronic speedometer will be about 2.100 Euro for export (without VAT). With mechanical speedo drive it will be 2.225 Euro Freight cost to the US about 50 Euro. For more info (upload of pictures is limited here) please send me a PM or better mail to info@bugat5speed.de Martin Bott Bug @ 5-Speed Germany |
Steve |
Jun 11 2012, 08:32 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
The most preferred 915 trans is the 1977 915 Trans. It's the last of the magnesium (lightest) and the first for the clutch return spring. Later 915 trans are aluminum. I think they are 20 pounds heavier than the magnesium trans. I think 1975 was the first for the 8:31 ring and pinion. 8:31 ring and pinion is much stronger than the earlier 7:31 ring and pinion. The 914 901 trans is also a 7:31 ring and pinion. The 7:31 ring and pinion on both 901 and 915 are both course thread and can share axle flanges and differentials including limited slips. The 8:31 ring and pinion 915 gear boxes also have higher gears for the bigger motors. They also have fine spline diffs and axle flanges. Pro or con I used a 1986 915 trans with Martin's kit.
Lo-Fi Version | Time is now: 16th May 2024 - 02:55 AM |
